Question about Brother LS-2125 Mechanical Sewing Machine
Zigzag my zig zag is not working properly its going striaght instead please help
  • meli_mp2 Sep 05, 2008
    ok the needle is going in a zig zag but not picking up the tread on the zag making the stitch straight
  • fiestagrill Sep 15, 2008
    I am having the same problem! I was hoping to find an answer.
  • 4 Answers
I already tried this problem. but u need to open your machine for an adjustment. its just loosing the grip inside it. and fixing the direction of the bobin holder. its hard to explain it here. if only i was there..
Posted on Sep 13, 2008
  • 33 Answers
When using your zig zag are you readjusting the needle from 0 either to the left or right, if you dont adjust the left/right margins the needle will stay straight and wont zz even though you have one of the selectors on zz you need both readjusted should be a small dial or lever on the machine and when you move it you will see the needle move as well
Posted on Sep 04, 2008
White 1521 only zig zag even on straight setting had it cleaned but still only zig zag zig zag on all setting how or can it be fix?
I don't think it needs to be fixed. If you want to zigzag, there are two setting you need to do. One is the stitch length and the other is the stitch width. When you sew a straight stitch, the width is 0. If you want it to zigzag, make the width wider (usually 1, 2, 3, 4, or sometimes 5). I've looked at the manual for this machine and page 21 has some info. There's probably more if you read further. If you don't have a copy, go to singer.com. They have tons of manuals for many brand of machines. Click on the support button and go from there.
Dec 02, 2017 | Sewing Machines
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
Mar 31, 2016 | Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Singer Touch and Sew Model 648 will not zigzag
There is an arm in the head that does the zig zag movement and attaches to the needle bar with a pin. If that isn't connected zig zag won't work at all.
Jan 19, 2013 | Sewing Machines
Morse 4300 fotomatic won't zigzag
if all the dial are set correctly for the zig zag, and the machine
still won't do the zig zag stitch then it's possible that there is a
gear or cam inside the machine that is worn or damaged.
a sewing machine shop can tell you for sure.
Nov 05, 2012 | Sewing Machines
Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Jun 03, 2012 | PfaFF Sewing Machines
Hello. I have a Singer Model 1411. I was going along, switched over to the zigzag stitch, and when I came back to the regular stitch, the machine thinks it's making a buttonhole instead.of a straight...
Well, I think you confused your machine. Go back to the zig zag and sew on a scrap piece of material. Stop sewing and carefully go back to regular stitching. Make sure your stitch length is correct and you have everything tightened up and the feed dog is raised. If this doesn't help, try doing a button hole stitch for a bit, stop sewing, go to zig zag, stitch a bit and go to the regular stitch and see if that works. If not, you may have to take it in to be reset. Good luck.
Nov 28, 2017 | Singer Sewing Machines
Zig Zag wheel not working
Need to know what type of machine, but most likely the connecting arm for the zigzag width to the needlebar is gunked up somewhere. Clean the joints of it and oil liberally with lots of exersizing it.
Mar 17, 2010 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
279 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
