Question about Microsoft Xbox 360 Console
Problems starting up
When i turn it on the middle light starts blinking like the trays opening, then goes straight to the dashboard (when the startup is normal it wont do this). then if i try and open the tray it wont open, and the xbox says the trays open. i dont know whats going on but its not looking too good... ill try and get a video up soon.
Sounds an odd problem... the motor on the disc eject system may have simply failed. you may need to send it off.
Posted on Sep 05, 2008
Whenever I start my BMW 745li & move out & stop somewhere. Then off the engine within 1minute to 5 minute, when I turn on the engine again the transmission light on the dashboard will start to blink & when...
Check your transmission fluid while it's in park and running to see if it's low,add when engine is off,goes in where the dipstick is,use a funnel.
Jul 31, 2017 | Cars & Trucks
The power light blinks, reads open tray/close tray . . .
it sounds like your dvd drive is dead if its still under warranty you should just send it back to microsoft the only other thing you could do is buy a replacement dvd drive and put it in yourself but only do that if microsoft wont take it or you'll void your warranty
Aug 25, 2009 | Microsoft Xbox 360 Console
Xbox360 tray ejects itself
The only thing i can think of is that something is stuck in the tray. Sorry about your luck
Apr 30, 2009 | Microsoft Premium System for Xbox 360
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Xbox stays on dashboard screen
Clean the back and the tray maybe the CD.
Dec 30, 2007 | Microsoft Xbox Console
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
