Question about Mitsubishi WD-57731 57" Projection HDTV
57" Mitsubishi won't power on, blinks green timer light
It sounds like you have the exact problem I experienced yesterday. The green timer light blinks on, I hear a fan powering on, then it powers itself back off again. Did you get a solution to your problem? Is it the same solution of replacing the capacitors? Or did replacing the lamp help?
  • 1 more comment
  • jesse70 Sep 11, 2008
    This happened to me too after a power outage (tv was plugged into surge protector). The timer light blinks but tv wont turn on.
  • uawildcat Oct 07, 2008
    I've got the same problem here. I've also had the air flow problem among others. These will all be solved as soon as I can get the thing to a tall cliff.
  • Dan Cobb Nov 17, 2008
    I didn't realize this, because it happen over time, but the screen was getting dimmer. Perhaps I watch too much television in the evenings and never watched it during the day when it was so nice out.
    The problems with the fan running, the green light flashing and not powering up (but sometimes I'd get lucky and it would), ended up being a warning of what was to come. The lamp was going, but it did not give me an accurate indication it was the lamp. Eventually, it did though. So, if you get the same symptoms I experienced, it may be a good indicator you need to order a new lamp. After all, My TV is about 2.5 years old and apparently that is a fair life of these lamps. It was our primary television for most of the lamps life.
    The good news is, replacing the lamp is a DIYer, no special tools, or lengthy complicated fixes.
    Problem Solver:
  • 4 Answers
It is a common failure of the 57" Mits. DLP. The problem is a defective thermistor and is covered by Mits. Contact a local repair shop and they will fix it free (parts & labor)
Posted on Nov 17, 2008
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Blinking green light (timer light). No video, no sound. Error code 12. This model has no DM board so it's not the better known "capacitor" problem.
Error code 12 signals that no failures were detected , which means that it's a power source failure. You will need to check it - the board sits on top of the main board.
Feb 16, 2011 | Mitsubishi WD-57733 57" HDTV
bad control box , dm3 board , this kine of repair $400
Apr 16, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Televison & Video
IMitsubishi 62525 timer light blinks green and won't turn on
Try a system reset by unplugging the set and waiting for about 3 min then replugging it in. If this problems persists contact mitsubshi for technical support, I have replaced entire signal board chassis for this same problem, they will run you through a few common things to try using the front panel buttons.
Sep 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Model WD-57731 LED Timer Light
You have a dm board problem could be the capacitors or you may need to change the entire board.
Sep 16, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-57731 57" Projection HDTV Logo
596 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
