Question about Minolta Di3010 Copier
Minolta Di 3010 Error code C0910
Hi
I have this copier but now fail error C0910 . When you power on the copier report this error C0910 and shut down the copier.
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'll have to look it up.
  • Minolta Master
  • 2,794 Answers
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Posted on Sep 06, 2008
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
C0910
Hello
C0910 shows that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there's any jammed paper.
Mar 04, 2011 | Minolta DI-2010F Copier
Call for servce code c004e
Its a failed Power Supply Cooling Fan Motor. Replace the cooling fan with part number 111T80010.
Dec 11, 2010 | Konica Minolta Bizhub c203 Copier
ERROR C0910 KONICA MINOLTA BIZHUB DI 2010
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Nov 27, 2009 | Minolta Office Equipment & Supplies
Delete error code C0910 or reset?
with the machine turned on open and close the front door
Sep 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Jun 26, 2009 | Minolta Di3010 Copier
Error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
Mar 30, 2009 | Konica Minolta DiALTA Di200 Copier
Konica Minolta Di450 Error C1326
how to remove di 470 minolta error c1029
Dec 17, 2007 | Minolta DI-2010F Copier
Minolta Di3010 Copier Logo
2,069 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
