Question about Dryers
Cannot get front panel off kitchen aid dryer to reach heating element model # KGYS850JQ1
  • jenbearmom Sep 05, 2008
    thank you very much
  • Anonymous Mar 19, 2014
    HOW DO I REACH THE PILOT LIGHT TO RE-LIGHT?
  • 5,911 Answers
Remove the front panel by following these steps:
1. UNPLUG dryer before servicing.
2. Open lint screen and remove lint screen filter.
3. Remove the two screws at the lint screen opening.
4. The top panel with console, should lift up at this point (you may have to pull it towards you slightly if there are retaining clips holding it in place).
5. Unplug the door latch plug (small white connector plug).
6. Locate the retaining screws that hold the front panel in place. There should be one screw on each side of the cabinet interior at the upper left and right corners of the front panel.
7. With the screws and connector plugs removed, the front panel should lift up slightly, then come off.
NOTE: Note the position of the small retaining clips at the bottom left and right corners behind the front panel. These clips will insert into two slots at the bottom corners of the front panel to hold it in place when re-installing.
I hope you find this information helpful. If you still have questions, please let me know.
PS You can go to searspartdirect.com and type in the same model number you provided. There are helpful exploded view parts diagrams that can assist you. The "Top and Console" and "Cabinet" headings will help you with disassembly (if needed).
Posted on Sep 04, 2008
Kitchen aid toaster
Test heating element for continuity
Jan 09, 2017 | Dryers
Does not heat
Hello there and thank you for choosing fixya
There are a few reasons why this is happening i have listed the most common items to check listed below
1st is the heating element this is the most common thing that fails
The heating elements are a common problem with dryers not heating and are an easy do-it-yourself repair. On the Newton style dryers, the heating element is located under the tub on the right in a round heater-can. To access it, first remove the front panel by removing the two screws on each side at the bottom of the front panel or if it's a newer model, prize the clips under the front panel. Then pull out the bottom of the front panel until the top clips release.This should release the top so that you can lift it up. Once up, you should see the heater at the back. Checking the heating element is the same for both styles. First disconnect power from dryer then unplug the wires going to the heating element. Next using your ohmmeter , check to see if you have continuity between the terminals on the heating element.
If you don't,have continuity the heating element is bad and needs replacing, if there is continuity the heating element is ok.
Mar 06, 2011 | Maytag MDE308DAYW Electric Dryer
My Amana Drier Model LE8407W2 stopped heating (everything else works fine). After checking the vent, I have decided to examine the heating element but am having difficulty accessing it. I have removed...
Most dryers are designed to be repaired from the rear. On the rear probably the whole back panel unscrews. Giving access to the duct where the heating element is located. Make sure to have the dryer unplugged while servicing it to prevent getting electrocuted. Your heating element will be inside of a metal duct that feeds hot air into the dryer remove it and inspect it for breaks in the coils of wire or burned areas. Having a good volt meter that checks continuity is a great tool to check dryer parts. There are several over heat sensors that can go bad over time to and can prevent the dryer from heating. These sensors and the heating element can all be checked using the volt meter on the continuity setting. Having a cell phone on hand helps to take pictures of wiring and connections inside the dryer before unhooking them to aid in reassembly. With sensors or element unplugged and a volt meter on continuity setting touch the red probe to one side of a connector and the black probe to the other side if there's no numbers or a beep on your volt meter suspect that part bad. I have fixed several dryers this way. Hope this helps you.
Jan 17, 2018 | Amana NDE7800AY Electric Dryer
Kitchen aid kgys750gq0 works but there is no heat
The KitchenAid KGYS750GQ0 is a gas dryer, so the solution of looking for a heating element is not helpful. There are several heat switches and a gas burner assembly (which includes a gas valve and an electric ignition), any of which could be the problem.
May 15, 2010 | Dryers
My kitchen aid dryer does does not reach the higher temperatures it used to--it takes a much longer time to dry clothes.-even when set at "high"
Please clean the entire vent system from the dryer to the outside.
Make sure the vent is not smashed behind the dryer.
Long time to dry complaints are usually due to restricted house exhaust vents.
To test...Remove vent from dryer and operate dryer with a wet load if the unit dries ok the vent is @ fault.
If not one stage of the heat element could be burnt out.
Jan 19, 2010 | Dryers
How to test heating element in kenmore h3 dryer
You can test the element while it is still installed if you like. Just make sure the dryer is UNPLUGGED, first. Dangerous voltage is still present with the dryer turned off. Remove the lower toe panel under the dryer door. This is accomplished by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the dryer up can provide better access. Placing the feet on a 2x4 works well for this).
You have to remove the blower fan housing to better access to the heating element. Make sure you reach inside the door and remove the lint screen first. Then, remove the screws holding the assembly in place and remove.
Disconnect the wires from the heating element before taking any measurements. This ensures your readings are accurate and you do not read any parallel resistance paths. Do a resistance check across the heating element terminals making sure you do not ground your leads to the element heater box. A good reading will be between 9 and 13 ohms. If you have any questions, please let me know.
NOTE: This is a good time to clean the dryer interior and blower fan, while you have everything removed.
Nov 15, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Trying to locate heating element on kitchen aid dryer
Do you have the part number, is so Put in (Find kitchen aid dryer Part# 111111* ) Or( Find kitchen aid dryer heating element* ). If this is a old dryer some parts are not made anymore. Any Dryer over 7 years old is no longer energy efficient. Hope This Helps.
Zipher
Oct 03, 2009 | KitchenAid Dryers
Dryers Logo
146 people viewed this question
Top Dryers Experts
