Hello
Check its loading belt and loading motor. If loading belt get loose or loading motor has low pulling power [due to trouble with its carbon brushes inside it], this type of problem will occur. There is a gear wheel assembly inside it which draws in and pushes out the tray mechanism. If any of these wheels gets broken, the mechanism won't work properly, even if the loading motor and loading belt is right. If so, replace the loading mechanism. It won't cost more, and can be bought from most of the electronic spare part shops at your town. OK.
There
are three common problems that cause the Soap Dispenser or Cup not to
open. I have a tip that will explain these problems in
detail....
Dishwasher Repair Problem Detergent
Cup does not Open
heatman101
