Question about Kenmore 62602 Electric Dryer
Dryer doesn't run on it's own or heat
Dryer does not stay running on it's own. When you hold down the button it will run but not heat. (I tried duct tape, but did not dry the load) We had a repair person come in who said we needed a new motor. It is still doing the same thing that it was before. He did not fix anything.
  • whittinc May 11, 2010
    When I tape the start button down it will run and dry clothers. I changed the relay for the door because it was broken - but it did not fix the problem. Any suggestions. Thanks!
    Genius:
  • 1,028 Answers
Remove end caps on console by pulling top part forward remove the screws under each end of console and roll console back AFTER UNPLUGGING POWER under console next to timer is a control bd to right are 2 black relays 1 with blue wires 1 with red try switching the relays if dryer stays running replace relay if not most likely the control bd especially if you see burnt spots on bd
Posted on Sep 05, 2008
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Won't stay on when button is pushed, HOLD button down it will run but not heat !!!! PLEASE HELP !!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 04, 2011 | Kenmore 9781 Electric Laundry Center with...
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
heatman101
Mar 19, 2011 | Kenmore Dryers
My kenmore elite dryer wont stay running after you push the push to start button. it starts runs only if you hold the button down. which i did for a shot period of time and also notice no heat starting...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Kenmore 63942 Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
104 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
