Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
My TV - Same Model is blinking 8 times -
You mentioned a specific problem for the previous person's symptom, how did you know that is what was causing it? I saw another blog showing how to use the remote for self diagnostics - is that how you know?
  • cj_neely Sep 07, 2008
    my tv turns on and after a few seconds of having a black screen with sound it turns itself off and than has the standby light flash 8 times. I have read that it is the flyback transformer on the d board but im unalble to locate this and would like to be able to identify the flyback transformer and the d board
  • Sony Master
  • 5,138 Answers
If your FBT was bad you would not even get no flashes, set will only click , sony has a high voltage capacitor located next to hori output transistor small blue 1200pf 2,000 volts 2k most of them develop small pin hole causing set to shut down.Hori output could also be shorted.FBT is gray in color has 2 wires coming out of top of it red&black one lead goes to high voltage trippler other goes to focus&screen control block.
Posted on Sep 20, 2008
  • ladywinn
    ladywinn Sep 20, 2008
    OK one person had same problem blink 8 times replaced high voltage splitter block this is where 1 of wirers coming out of FBT goes to Part number is 8-598-955-32, how to tell if splitter block is bad remove lead coming from FBT make sure wirer is away from you and anything on chassis if high voltage comes up after disconnection from splitter it means splitter is bad.trippler/splitter same thing.
BLINKING CODE LIGHT 5 TIMES
Different brands have different blinking codes. you didn't mentioned anything about the TV like brand and model number. any why check the following link using search tab fin your tv and and its blinking coed causes
www.electro-medical.blogspot.com
Oct 30, 2015 | Televison & Video
Wont turn all the way on
Power supply failures involve more than just faulty capacitors.
Jan 15, 2014 | Samsung LN40B750 40-Inch 1080p 240 Hz LCD...
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Tv turns off red light blinks 9 times
Sony tv led and blinking codes
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I hope this will be of some help to you
Mar 22, 2012 | Sony Televison & Video
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Sony KP-51WS500 turns red ,shuts off, led blinks 8 times
Here are the fault codes for your tv and what components are affected:
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
Apr 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Blinking stand-by light
I'll need to verify this for your specific model, but usually the 6 blinks means that there is nohorizontal pulse. The 7 indicate a high voltage shutdown. Since the symptom changes, I would look first for poor solder connections in the horizontal circuit. Can you solder? If so, update this and I'll try to provide more details.
Dan
Sep 10, 2008 | Sony KV-35V65 TV
TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV-34HS510 blink codes
I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
