Question about Microwave Ovens
I have a new microwave MSE 23 i bought it 1 month ago. It has been working fine maybe use it 6 times a week. I put jacket potatoes in tonight when i went to get them out they had not cooked but felt warmish.Tried a few more times to no avail. Can you help.
  • 706 Answers
If your microwave oven is ONLY 1 month old and there is any question with its performance, it should still be under warranty from the manufacturer so I would bring it back to where you purchased it and have them provide a replacement of have them demonstrate that the one youi have is working to spec. Conversely, if you put large potatoes in the microwave, they havea lot of mass to them and will need to cook for quite a while.. Have you tried anything else in there of smaller proportions and those did not cook? You should be able to boil a cup of room temp water in a minute or two.. If that fails.. bring it back..
Hope that helps
Posted on Sep 05, 2008
Samsung microwave ME21K7010DS displays C-10 when I select potato. Stats working but after about 2 min message C-10 appears. Works fine in other settings. Microwave is about 14 months old
Older microwaves can develop any number of quirks.
Instead I suggest calculate the number of cooking time minutes needed and use that for your potato.
Be sure to fork a few holes into the skin of the potato so it doesn't "blow" and redecorate the inside of your micro.
Jan 02, 2018 | Samsung Microwave Ovens
240V Advantium - Halogen Speedcook Not Working
If purchased "new" 6 months ago, it should still be under warranty. Call repair service....
Oct 18, 2014 | Microwave Ovens
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 12, 2011 | Microwave Ovens
Sweet potatoe caught fire in my microwve
the magnatron super heated the paper combined with what we in the industry call super combust your micro should be ok to use just keep it clean and if you use toweling wraP it around rather than cover
Apr 21, 2010 | Amana ACO1860 Microwave Oven
Microwave oven no. NN-A514 cuts out when cooking
I had that issue and I opened the unit and there was a fuse near where the power went in. Went to the small local hardware store and they ordered it. It was well under $5 (can't remember) but it still works over 10 years later.
If the fuse blew again I would have trashed the unit.
Dec 21, 2017 | Panasonic Microwave Ovens
Fuse blows on microwave switch on
one of three things shorted could cause this: H.V. diode,capacitor,or the magnetron tube, take screw driver and short terminals on capacitor before touching anything inside the case, then chk resistance on capacitor should show infinite after needle settles, diode should show hi resistance one way and a lower resistance in the other direction(use the RX100 scale not the RX1) on both parts diode should not show very low resistance or it could be leaking,mag is a different story,it can be chk'd but in a different way
Jul 24, 2009 | Panasonic NN-H275 Microwave Oven
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
Only some of my keypad will work
if your keypads dont work maybe the cushion or spring beneath is worn, so check your dealer with your warranty documents so you can get it exchanged
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
