Question about Roper REX4634KQ Electric Dryer
Roper clothes dryer not drying clothes
The heating element works but it takes 3 to 5 cycles to dry clothes
  • Anonymous Mar 24, 2014
    Takes 3 hours for clothes to dry.
  • 5,911 Answers
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Posted on Sep 04, 2008
THAT SEEMS TO HAVE FIXED THE PROBLEM. NOW I JUST NEED TO REPLACE THE VENT.
THANKS
Posted on Sep 05, 2008
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
No heat/Only works on one setting
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 08, 2012 | Roper Dryers
Having heating problem with Roper REX4634JQ0 dryer?
probably have a weak hi-limit thermostat on the element housing or cycling thermostat on the blower housing
Apr 26, 2012 | Roper Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
What would cause intermittant heating in a Roper Electric Home Dryer?
the dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
Nov 20, 2007 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
822 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
