Question about SanDisk Sansa E280 MP3 Player
My desktop (XP Pro SP3) does not recognize my Sansa e280
When I first connected the player to the desktop it was recognized. After SansaUpdater was installed, the player says "Connected" but XP says nothing (device manager does not show removable drive either).
Roinuj
  • 1 more comment
  • brantleyalex Sep 05, 2008
    I have also plugged the player into each of the 5 individual USB ports, have restarted XP numerous times, and alternated between MSC and MTP USB connection on the player. So far nothing makes XP recognize the player although each time the player says it is connected. ??
    The player works great. I just can't get XP to recognize it so I can't synch or drop recording into it.
    I have used two different cables for the e280. When I connect to my laptop the computer recognizes the player but not all of its files. For instance the Music file is missing, so I have no way to synch or drop MP3s. The primary problem is my desktop acts as though the player has not connected while the player says it is.
    Scholar:
  • 141 Answers
Try going into the control panel/administrative tools/Disk options
Change the drive letter of the Sansa (if it shows up) or any other removeable drive that may be conflicting with the drive letter. This includes network drive mappings.
Posted on Sep 05, 2008
  • 983 Answers
In the player settings there may be an option something as "USB mass storage device" enable that if so ....
  • 3 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Sep 05, 2008
    try it in another pc once ... if you are not sure that the USB ports are working properly or not....
    after you plug it in try going to control panel >add hardware once and check whether will it detect or not
    there may be some problem either in the USB ports of your pc or in the port of your player or in the cable from which you are connecting ...
    there may be some manufacture defect .... make use of the warranty if you have it ... before that try it in another pc ..
    because there may be some problem in the OS in your pc...
    once you try resetting your player i think there is a option in player
  • 435 Answers
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player, there are 4 solutions you can try:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If you're running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – Download and Install the MTP Porting Kit
SOLUTION 4 – Try connecting the device to the PC using MSC mode
View/c200: Turn on & press and hold the rewind button while connecting to the PC
Fuze/e200: Go to Settings > System Settings > USB Mode & select MSC
Clip: Go to Settings > USB mode & select MSC
  • Narmada Anand
    Narmada Anand Sep 05, 2008
    It could also be a problem with your mp3 player's usb port.
    Try the first four steps mentioned..........If they didn't work then revert back to me because it be usb port problem of your mp3 player.
    Hope to hear from you soon.
    Thanks
    President:
  • 1,263 Answers
Try uninstall of the updated driver. then istall the original driver and connect the usb to the player. this should work. apparently the update may not work with your model of player or the updated driver has a glitch. please rate if successfull
    Master:
  • 638 Answers
The software problem is there in the system.
call a technician at your place and he will upgrade the software and it will work.
hope this solves your problem.
thanks.
please rate the solution.
    Master:
  • 763 Answers
If your player still unrecognizable by your computer then try another usb device and see if still the same happening. if not then try to download a USB driver from www.usbman.com
try to use windows media player and rip your recordings to it. you can adjust by the quality of yuor recordings and rip it with types like mp3 or wma. if your mp3 is containing with mp3 files then it should be dropable. hope that helps!
CHARCOIS
    Sergeant:
  • 264 Answers
If the installation of the sansa updater was recent. i will suggest to do a system restore.
The steps are mentioned below.
Start>All Programs>Accessoraies>System Tools>System Restore>Next
Choose a date when the sansa updater was not installed.
System restore takes your system back to a previous date and any software changes on the computer and reversed.
I hope that helps
All The Best
Sammy
    Genius:
  • 2,028 Answers
I'm going to recommend that you remove the software and updater for the Sansa and reinstall it. It sounds as if you had a bad download.
  • Ryan Rogers
    Ryan Rogers Sep 05, 2008
    Still going to say bad download, and reinstall the software and drivers.
    Genius:
  • 1,269 Answers
Try to use a different USB cable.
  • Michael Galve
    Michael Galve Sep 05, 2008
    Turn off your computer. Turn off the player. Turn on the mp3 player first then the computer. Check if that fixed it.
  • SanDisk Master
  • 6,487 Answers
Try to unplug/replug the player or better try to connect it on a different USB port then after that restart the computer that should do the trick..
Hope that helps.....
Posted on Sep 04, 2008
  • Mark Gil
    Mark Gil Sep 05, 2008
    If that's teh case the next thing that you can try here is to connect this player on a different computer and hopefully it will be detected on a different computer if still not this can be a problem with the software of the player...
  • Mark Gil
    If there's any software update for the player you can do that first and hopefully it will fix the problem of yoru player..
How do you reform a Sansa E280E MP3 player. video files stored is corrupted and unable to be deleted through normal means.
Hello there...
To format your mp3 player please do the following
Connect one end of the USB cable to your player and the other end to an open USB port on your computer. Your computer will recognize the new device.
Double-click "My Computer" on the desktop. You will see your Sansa e280 player's icon listed as a removal disk together with other hard drives on your computer.
Right-click the Sansa e270 icon. Scroll down and click "Format." When the format window opens, click "Start." The formatting will erase any current information on the drive. Depending on the memory capacity, it could be a quick process or take a little longer.
I hope this solves your problem,,,
Jul 03, 2010 | SanDisk Sansa E280 MP3 Player
My Sansa e280 will is not being recognized by any PC in MTP or MSC mode. Windows XP is operating system.
i would suggest reinstalling the device or removing the device and letting the computer restart to see if that works if that dont work then use the CD that came with the device finally if that dont work contact Customer Support and see if that helps =)
Sep 02, 2009 | SanDisk Sansa E280 MP3 Player
I bought a Sansa clip for my mom for Christmas and i downloaded some music on it and it worked fine but when i went to put more songs on it, my computer won't recognize it. Is it because of SP3? It would...
This happens quite often with USB drives in general. Start by plugging it into another computer (minimum WinXP). If it works there, nothing is wrong with your player, but your computer has "lost" the driver. Fixing things so the player is again recognized by that computer is complicated, and some choose to reformat the computer, or use a different computer to maintain the player. Explaining exactly how to do fix your computer is a bit too involved to do here. I haven't found a definitive guide, but several suggestions by searching Google for: won't recognize usb drive
Jun 08, 2009 | SanDisk Sansa E280 MP3 Player
Computer doesn't recognize MP3 player -
Try to reboot your PC. Leave mp3 player off when start Sync (if button lights up this time).
Jan 20, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
Where can I find a e280 driver?
Try uninstall USB controllers and reboot the computer.
Then connect the sansa and try.It should work.
It worked for me.
Jun 04, 2008 | SanDisk Sansa E280 MP3 Player
Computer does not recognize my sansa clip
Same problem, my sansa was working great did a windows XP update. Now my it won't show up on my computer.
OS: Windows XP Media Ed
HP Media Computer.
Thanks a lot Microsoft, messing a working machine!
Apr 18, 2008 | SanDisk Sansa E280 MP3 Player
Sansa E280 isn't recognized by Vista
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Mar 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa E280 Feeding USB of car stereo
That device does not recognize the Sansa firmware - there is no driver for recognizing it
Nov 06, 2007 | SanDisk Sansa E280 MP3 Player
Usb problem
With the device connected, check the Device Manager for errors (red or yellow) on Mass Storage Device and update the drivers on them.
FYI - you need to have Windows XP / SP2 and Windows Media Player 10 or higher for the device to connect to the PC.
You can add to this question for additional support.
Best of Luck.
Oct 10, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
85 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
