Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp officejet 7130
Have a all in one printer,model # c83894, and i need a power cord,cd,usb cord. this was given to me with out those things where can i get them
    New Friend:
  • 109 Answers
Legitimate buyer/s has a right for full products presentation, pls inquire matter to the shop where purchased the item and demand the accessories missing.
Posted on Oct 17, 2008
I cannot clear the "Door
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | HP OfficeJet 7130 All-In-One Printer
Problem for HP Officejet 7130 All-In-One InkJet Printer tells me to close ink cartidge and its CLOSED! Thanks
The full-featured HP OfficeJet 7130 all-in-one offers photo printing, double-sided printing, an automatic document feeder (ADF), a fax, a scanner, a copier, and inputs for all of the current breeds of photo memory cards on the market today. At first blush, the machine's large footprint may seem overbearing--until you take into account just how much space you're saving by putting all of your technological eggs into one basket. Unfortunately, the 7130 isn'
Jul 16, 2010 | HP Officejet 7130 All-In-One InkJet...
Streaking effect during printing Officejet 7130
As you have replaced the both cartridges and still the issue persists, then this is a hardware issue with the unit. Please repair your printer.
:) Dr Tony
Apr 14, 2010 | HP Officejet 7130 All-In-One InkJet...
Power lead missing
Hi Tony,
I looked at the specs for your particular HP Officejet 7130. It is extremely important to connect the correct powersource to this type of printer. All types of electrical appliances have specific amperage and wattage requirements. Connecting the wrong power supply could cause serious damage to a possible electrical fire. The following link is the installation instructions for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06196&lc=en&dlc=en&cc=us&lang=en&product=91466
On this next link, you'll find the Product Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06193&jumpid=ot_recdoc/bpu06196/en_us/bpu06193/loc:2&custom_solutionid=rd_bpu06196&lc=en&dlc=en&cc=us&product=91466&lang=en#N3153
Your particular printer requires a 100W and no more than 2.5Amp Max. You can call HP and inquire on a replacement power supply. The two parts that you need that are sold separate are the power cord and the power module. You will have to call HP at 1-800-227-8164. The power module replacement part no is C27296-60043. The power cord part no is 8120-6260.
Best of luck!
Apr 17, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
Printer copies come out blank
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP Officejet 7130 All-In-One InkJet...
Installation CD for Hp officejet printer Model 4355 lost .
I have lost the installation CD given along the printer model 4355 Hp officejet. Please let me have the link from where the required programme can be downloaded.
Oct 13, 2008 | HP Officejet 4355 All-In-One InkJet...
Officejet 7130
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Aug 18, 2008 | HP Officejet 7130 All-In-One InkJet...
HP Officejet 7130 "Scanner Failure"
Scanner failure usually means you'll have to replace the entire scanner unit.
When the machine turns on (or gets plugged in), does anything happen...any lights come on?
Is the machine able to print from the computer and recieve faxes while the scanner error is present?  If so, you probably need a scan unit.
Oct 29, 2007 | HP Officejet 7130 All-In-One InkJet...
HP OFFICEJET 7130 ALL IN ONE
pls download the driver from this link http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=91466&lc=en&cc=us&dlc=en&submit.y=5&submit.x=10&lang=en&cc=us bye.
Sep 21, 2007 | HP OfficeJet 7130C All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
