Question about RCA 32F531T 32" TV
RCA TV to DVD Player
I recently lost the cable that connects my TV to DVD player. I purchased a Zenith replacement but there is no sound. I have rechecked to make sure that the colors are in their correct conectors. What should I do next?
  • 374 Answers
Norm, I am assuming you are using component cables. Check to make sure you have the lines ran into the TV in ports e.g. Video1, HDMI1, HDMI3. Also check to make sure the system is not on MUTE or that the internal speakers on the TV are not turned off. If that fails and all was well before the new set of cables try another set.
Posted on Sep 05, 2008
SOURCE:
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Connect jvc dvd to zenith tv
just hooked up with an rca cable from the output jack ( audio/video ) of your dvd recorder then the other end connect to the input jack of the tv. then set your tv at the same time the dvd player to record.
Aug 11, 2012 | JVC DR-MV150B DVD Recorder/VCR
I would like to be able to connect the Zenith portable DVD player to my TV to watch DVD's on my TV. I have a model number ZPA-314.
If your DVD player and TV have RCA jacks, (3 wires: 2 audio, 1 video) simply patch between the two. If TV does not have RCA jacks, plug the DVD wires (3) into the 'line input 1' on VCR. This way, the VCR is acting as a 'converter' btwn. the DVD player and the TV.
Feb 05, 2011 | Zenith DVP615 Portable DVD Player
What kind of AV cable is used for the Kawasaki PVS10921 Portable DVD Player? I have the player itself, but lost the AV cable to connect the player to my TV, and I've been unsuccessful in my attempts to...
The cable supplied with the player splits the audio feed from a single audio jack to dual RCA jacks for connection to a standard VCR or TV. The video appears to be a straight RCA to RCA type connection where a standard cable can be used.
See the users manual here:
http://www.1800customersupport.com/productdocuments/PVS10921%20Product%20Manual.pdf
Dan
Aug 26, 2010 | kawasaki PVS-10921 Portable DVD Player
I do not find a vedio/audio(red, yellow, white)ports to connect to my DVD player. What is the alternative way to connect to my DVD player using this TV? Thanks
There are 5 RCA connectors on the back of this TV, (according to the manual). The lower three from left to right are Video in, Audio Left in, Audio Right in. There are also two RCA connectors above these that are the L/R audio outputs. Also, there is an S-Video input which I would recommend using instead of the RCA Video in. You'll still need to use the RCA inputs, but the S-Video will give you the best video connection into this monitor.
Oct 31, 2009 | Zenith C27A24T 27" TV
How to Connect Converter to TV, DVD/VCR and a Stereo?
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Jun 15, 2009 | Philips DVDR3435V/37 DVD Recorder/VCR
AV Out cable for portable Zenith (DVP-615) dvd.
I lost the AV cord to my Zenith DVP-615 portable DVD player too. I bought a standard RCA AV but it did not work. I found my cord so I was able to compare.
The standard RCA AV cable has a 4-part mini-plug. The tip is white, next is yellow, next is ground and the base is red. For the Zenith DVP-615, the tip is yellow, next is white, next is red and the base is ground.I never found where to purchase a replacement but perhaps this will help someone make their own.
Jul 15, 2008 | Zenith DVP615 Portable DVD Player
No audio
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Jan 05, 2008 | RCA RC5510P DVD Player
DVP615 A/V cable
I don't know if the person who posted this problem checks back for the answer.. but I just called Zenith.. who's actually run by LG now I suppose.. Anyways, the customer service rep verified that the a/v cable is just the standard RCA a/v cable that you can pick up anywhere, so it should be easily replaceable if you don't find the original..
Nov 14, 2007 | Zenith DVP615 Portable DVD Player
RCA 32F531T 32" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
