Question about Norcent Technologies2703 27" TV
NORCENT PT -4233
WAS WATCHING TV HEARD A POPING NOISE SCREEN WENT BLACK BUT WAS STILL ABLE TO HEAR SOUND
  • 3 Answers
Norcent PT4233 no picture, black screen, but has sound. How to repair
The display (PDP - Plasma Display Panel) at the heart of this unit is a LG 42V7 model. There is a known bad solder "defect" on the YSUS board that causes this board to fall unexpectedly.
The bad news is that you have to replace all the primary boards on the display - ZSUS, YSUS and CTRL boards, as the failure can/often takes them all out.
The good news is that LG makes a repair kit for this panel. Its part number is 687VSNB03E and it contains the three boards LG6871QYH036D (Y SUSTAIN), LG6871QZH041B (Z SUSTAIN) and LG6871QCH053G (CTRL).
Hope this helps
Posted on Feb 07, 2009
    New Friend:
It's actually 6871VSNB03E for the replacement kit.
Posted on Jan 24, 2015
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
Jul 10, 2013 | Televison & Video
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Screen went black after hearing poping noise and seeing smoke. The vizio light will turn off and on but screen remains black without sound.
Your power source or projector has definitely short putted, i would recommend replacing the parts.
Jun 24, 2010 | Televison & Video
TV will not power on.
I guess your TV is DLP.
Please notice the follow symthoms:
When you on TV, did you hear some strange noise from the back of the TV. If yes, the color wheel needs replacing.
If no, check the lamp. Take a look to bottom of lamp, you will see white pot or sometime a pop up there due to lamp cycle is going to end. When changing lamp, check the ballast and power sup, too. If you see caps are poping up. Pull out those board and replace the poped caps.
Aug 13, 2009 | Televison & Video
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Sony KDF-50WE655
It sounds like the lamp is definitly bad.
Look at it and more than likely it is broken.
The lamp is located in the front of the set. The bottom front is a cover that has a dial on each side of the back of the sets that can be turned by hand (counter clockwise) holding the front panel in place.
There is a metal strip that is holding a door in place and can be removed.
The lamp is being held in place by a screw that needs to be removed with an allen wrench.
There are several places that you can buy lamps online.
This is a link that this site advertises that has do it yourself instructions:
www.AMatterOfFax.com Reply to this post if you have any questions and I will respond.
Dec 01, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Norcent Technologies2703 27" TV Logo
709 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
