Mac printer Hp Printer
No I haven,t but the printer is working with the hard drive & also I have a Toshiba sat A10 laptop which prints wirelessly thru the set up really good
The mac doesn,t seam to be able to to find the router for printing but can find it for internet
  • 2,794 Answers
It's because your printer is set for sharing on a windows based network. Mac has a different network for sharing printers not compatible with windows.
The only way to get it to work on the network is to get a print server either wired or wireless and connect the printer that way to your network. Then everyone can use it.
Posted on Sep 04, 2008
NB255 does not see my hp laser 1018 wireless printer
Insert CD that came with printer and install the program. Or go to HPsuppofrt website for drivers and enter the model no. of the printer to get program and driver. Then reboot with printer hard wired to computer. Follow printer setup procedure to get to the selection of wired or wireless installation. Try Add Printer thru Control Panel, you may have to select Add Network printer.
Feb 28, 2013 | Toshiba Mini NB255-N245 NB305-N440BN...
How to add hp 2025 printer on mac laptop via wireless network?
Hi. There are two steps. First the printer must be connected to the wireless network - see the installation instructions that came with the printer. The mac is not involved in this part. Until you get it done you will not be able to do anything else.
Second. make sure you have the most up-to-date drivers for your printer installed on the Mac (this applies to any printer - not just your HP). Once the drivers are installed, go to System preferences and select "Print & Fax". and hen click on the + sign to add a new printer.
Wait a moment or tweo and the printer's name should pop up. Click it's name then wait for the drivers to be identified - this can take several minutes so be patient. As it's an HP you will probably get a bonjour connection but a word of warning, I have had more trpouble getting Macs and HP ptinters to work reliably over WiFi than any other make.
Apr 06, 2012 | Apple MacBook Mac Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          I have mac laptops and hp laptops. My mac laptops print wirelessly to my hp L7780 and my hp laptops have trouble
          exactly what kind of trouble , it can be related to any internet security or antivirus installed in ur HP laptop which is blocking IP of the printer to connect to ur Laptop and print . pls go to controll panel of ur Windows Os in HP laptop and uninstall the Internet security from HP laptop
          Apr 18, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
          Printer status says offline, and we can not print on laptop
          If you're offline with the printer, you definitely won't be able to print.
          I'm assuming you're using Windows XP here. Most Windows products will be similar...
          On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
          Good luck! Remember to rate the solutions!
          Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
          Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
          I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
          Feb 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
          Cannot print over the network
          dear sir..
          for vista u ned to install "netbui" componant to network device and when u install it's u need to connect mac pc to vista thru network then it's connected it's worked... it's help u..:0
          dear sir,
          there is no need to install any drvier install in to windows xp if yr pronter allreadt install in pc then right click on printer then got to shring then select share as then give a name... after this prossess go to windows vista and open yr pc thru yr network placess it's show printer which connected to windows xp just dabble click then it's show u "Are u sure to install network printer" somthing like that... just click yes or ok... it's help you..:)
          dear sir,
          her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
          plese vote
          Nov 23, 2008 | HP PSC 1350v All-In-One InkJet Printer
          Mac os to H P 5610 printer
          Do you have a spare usb port on your computer that you can use?
          Just in case the one in the back of your hard drive isn't working.
          Sep 04, 2008 | Computers & Internet
          Computers & Internet Logo
          74 people viewed this question
          David Payne
          David Payne
