Question about Dell E173FP 17" LCD Monitor
Dead monitor dell e173fp lcd monitor
Hi
my monitor just went dead, for no apparent reason, tried to restart pc no luck. no power light checked all leads etc. when pc starts nothing happening with monitor
    Sergeant:
    Champion:
  • 284 Answers
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
jonno
Posted on Sep 05, 2008
The monitor will not come on when i turn it on
1. - Check for power at the socket. (plug in something else)
2. - Check for power at the power cable. (plug the cable into something else you know works)
3. - Plug into monitor, and see if ANYTHING lights up when the power switch is turned ON.
4. - If you get some indication of power, try a new cable to the PC, or plug into different PC. That will localize if it's the monitor, the cable, or the PC.
May 28, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
When I connect the power to the monitor Dell E173FP 17, power bottom commence to turn on and off repeatedly...
Power LED is turning on and off because the power supply is in shutdown-restart mode becuase it sensing over current draw, it can be bad caps in power supply, shorted tramsistors (c5707) in the inverter circuits. See pictures: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Check the fuse and the transistor out (check Emitter and Collector pin for short circuits)
Mar 04, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My monitor will not stay on
have you tried running your pc in safe mode, to do this press f12 on start upjust before you see the loading windows bar. choose safe mode if this works then remove you orig video drivers and restart pc.
Nov 28, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Auto adjust on my dell E173FP keeps flashing on/off.
You probably did not get a response to your message because it posted as a 'new' mesage rather than being attached to your original to which someone had responded.
Check under the 'My Profile' link on the upper right of the page and your first message should be listed there so you can answer the (apparent) clarification request.
Dec 12, 2008 | Dell E173FP 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
Blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Apr 28, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
200 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
