The nylon gears have handy timing marks,however,I have no manual,and a certain starting point for the tape cradle is crucial,and possibly the position of other moving reverse actuators.Trial and error with 6 to 7 multi-toothed cogs has had me give up after hundreds of attempts short of purchasing a manual{more expensive than the VCR.Converting my 1965 VW beetle to water-cooled engine was easier.Its an older panasonic NV-F65 HQ
Yeah,I should chuck it and find closure on hoarding almost obsolete things.The 65 beetles OK though.Yeah,I should chuck it and find closure on hoarding almost obsolete things.The 65 beetles OK though.
You can't post conmments that contain an email address.
You do realize that you can purchase a new VCR from Walmart for less than $20. That is less than most places charge for the manual. I'm going to suggest a new VCR, versus the headache and hassle of fixing this one.
Yeah, I would definitely keep the Beetle, they're not quite the dime a dozen the VCR is. Used to be able to find the old Beetles all the time, made a few buggys out of them, but you don't see them much anymore, getting hard to find.Yeah, I would definitely keep the Beetle, they're not quite the dime a dozen the VCR is. Used to be able to find the old Beetles all the time, made a few buggys out of them, but you don't see them much anymore, getting hard to find.
go to mcmelectronics.com and order the replacement belt kit. then google your model number on alignment pdf. Your mechanism is out of alignment due to bad belts
If you cut the tape and freed all particles that usually would release the cassette, but you also mentioned it was binding which means there is a loading basket problem and is pulling on the one side of the basket, this indicates a bad gear linkage and the one cog wheel is likely bad throwing the load and eject sequence right out of sync. To fix this! will require parts and the labor to re-time the gears and cost factor will probably higher than what you paid for the vcr.
This needs a little bit of care but essentially you will need to unplug the power from the VCR then do the following: Remove the top cover Then with the front of the VCR facing you look to see if any of the tape is wound around a large metallic silver drum, that is tilted upward and is not flat, at the rear of the tape casing. If so then it means that it has wound around the drum and you will need to retrieve the tape to allow the eject mechanism to work. Do not touch the shiny polished part of the drum. To get the tape in usually means that you have to locate a plastic or metal cog wheel, usually on the right side of the VCR that you can turn with your finger. This makes the VCR motor move. Also there is one that works the tape eject mechanism. If you can find the one to wind in the tape before working on the one for the tape eject than you stand a chance of rescuing the tape, if not then it will get some damage. Don’t worry about turning the cog wheels with your finger as you can do very little harm to the VCR with no tools involved and no power on. Moving the cogs this way will only cause very small movements with the tape motor and eject so you will need to be a little patient and you will soon see what is happening. Once remove run a cleaning tape through the VCR before you use it again. With the limited space available her it is difficult to give you much more info.
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
The service manual should have a procedure for aligning the gearing,
BUT a lot of times they don't. Almost always, you can figure it
out as they put little tiny arrows or marks molded into the gears
showing which teeth line up. This usually is done in in the eject
position.
If you succeed here, you can regard yourself as "mechanically inclined".
Hope Ya Fix It.
try opening the case. then, using your fingers, roll the gear that drives the tape eject mechanism until a full tape eject limit is reached. power up and try
