Question about Whirlpool GH7155XHS Microwave Oven
ELECTRICAL POPING SOUNDS
MY MICORWAVE IS MAKING AN ELECTRICAL POPPING SOUND AND HAS A SMALL SCORCHED SPOTT ON THE INSIDE BACK WALL. WAS WONDERING IF IT WAS WORTH FIXING OR I SHOULD JUST REPLACE IT. UNIT IS ABOUT 3 YRS OLD
  • KEITHM135 Sep 04, 2008
    IT DOES NOT HAVE A RACK, ALSO THE NOISE SEEMS TO BE COMING FROM THE BOTTOM OF THE UNIT, NOT IN THE COOKING AREA ITSELF.
    Scholar:
  • 59 Answers
Hi there - I assume you have a rack in the Microwave. What happens is the rack due to putting something in and out of the Microwave some times wears against the back wall of the cooking chamber. As this happens it wears through the paint and exposes the metal casework.
You then get microwave arcing between the metal rack in the microwave and the cooking compartment casing which gives that spitting popping sound. I would say get some white model paint and paint over the scorched spot (as long as its not gone so far as to wear a hole in the case work).
Wait for it to dry and stick the rack back in and try again to warm up a cup of coffee or something and see if it stops.
Also if you pull the grill slightly forward in the holders towards the door and test it you may notice that it doesn't pop as much so I would paint it and pull the grill forward and see if you still get the issue.
Best of luck.
Posted on Sep 04, 2008
  • kevellen Sep 04, 2008
    OK if thats the case its something more major is wrong with the unit, I would say if you have scorching on the back wall without the unit having a rack I would definately want to get rid of the unit and replace it.
    Sorry to not be more helpfull
Frigidaire PLMB209DCB 1200W Microwave. Mfg 2005. Started sparking and loud popping. Scorched cardboard covering. Worth looking at to repair?
No, Your better off buying a new one. Sounds like the Magnetron is acting up and that is the most important and dangerous piece of hardware in the Microwave.
Jun 08, 2011 | Frigidaire GLMV169 Microwave Oven
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Jan 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Pop pop Kenmore hood microwave 665.60652 - year 2002
hmmmm, i wonder if you have a gear or something similiar to this going out. (turn tables)
If not, something tells me you have a component that is arching inside of your micrwave. I would call someone to double check to make sure it is ok.
You will be surprised at how many people wait until it is too late to service their units, when it goes out, it is gone.
good luck
May 25, 2008 | Kenmore 62702 Microwave Oven
Sanyo EM-G2585W 800 Watts Microwave Oven
It's possible that the unit is overheating, and shutting itself down to make sure that it doesn't melt or burn. Do you have it against a wall, or in a cabinet where the unit cannot vent? Is there a fan? Is it working? --j.
Jun 19, 2007 | Sanyo EM-G2585W Microwave Oven
Home Circuit Breaker Pops When Door Is Opened
It does sound odd for it to blow the breaker. It should blow the fuse, not the breaker. But looking at the exploded view diagram, I don't even see a fuse! Makes me wonder if this is some foreign model. *grin* In any event, you will need to replace all the door switches since they all have been stressed by the same overcurrent. Also be sure that all the switch mount and door latch parts are activating properly when you open and close the door. The switches (generic replacements) are widely available from local appliance parts stores. If you need any other parts, you can see an exploded view and parts list here: http://www.geappliances.com/shop/prts/
Dec 16, 2006 | GE JE2160 Microwave Oven
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
Oct 04, 2006 | Kenmore 62642 / 62644 / 62649 Microwave...
Whirlpool GH7155XHS Microwave Oven Logo
195 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
