Question about Sanyo PLV-Z2 Multimedia Projector
New Sanyo PLV-Z2 not bright
I have replaced the PLV-Z2 lamp for the first time after almost 4 years.
However, with the new lamp, the image is so dim, it is un-watchable.
I followed the installation instruction in the manual which is very straight
forward.
Did I get a faulty lamp or I'm missing something here.
Thanks for all the help.
  • 1 more comment
  • kuteo Sep 04, 2008
    As far as I know, this is a new lamp and it is for the Sanyo PLV-Z2.
    The current lamp is still functional, except that there are hundreds of
    little bright dots that become visible in a dark scene. As far as
    brightness and contrast, I could see very minimal degradation if at
    all.
    The lamp indicator light on the projector has been yellow for quite
    a while now, so I think it it will blow anytime.
    Thanks for any helps that can be provided.
    -kuteo
  • dannel Jan 06, 2009
    I have the same bright dot issue in dark scenes, does anyone know what is the cause as it only seems visable while using the DVI input ?
  • Anonymous Jan 24, 2009
    I am having a problem with some green spots showing up in the Left top hand coner, got a new blub and still there any answers?
  • 10,594 Answers
Is this original lamp or refurbished one or compatible some thing.
how was performance of previous lamp when you pull out it? if it is still working for few minutes, you can confirm projector by reinstalling it.
Posted on Sep 04, 2008
  • Shahid Electronics
    Shahid Electronics Sep 04, 2008
    Projector might need cleaning of dust inside lens and lcd assembly. use air-blower and clean it.
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
Blue haze/fog all over screen
As it appears from the images that the images are fine. The sanyo PLV-Z2 is a LCD projector. So basically it projects 3 R G and B lights to make the screen. Yes it is definately not a LAMP issue. Either dust could have accumulated on the R and G panels thus leading to these prominent BLUE patches or if the LCD panels are damaged, u have to get the G or R replaced.. try running a application like Displaymate from "http://www.majorgeeks.com/DisplayMate_d4189.html" and see which of the panels is exactly responsible for the problem. I think this should sort it out.
Dec 26, 2007 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV-55WHD1 picture too dark
It may be the lamp itself, some will dim just before failing.
Average life is 2000 hours or two years for OEM lamps and much less for generic ones.
Dec 22, 2012 | Sanyo PLV-55WHD1, PLV-65WHD1 Projection TV...
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
What is the lamp life on a sanyo plv-z2 bulb and how to read the bulb life there are 3 numbers that come up when i check it
If I remember correctly, you hold down either the power or the menu button for 30 seconds... I believe it is the power button, and it will briefly display it on the screen, but this assumes it was reset at the time the lamp was installed. The counter counts up on this model, and the lamp replace light will come on at 3000 hours. I have 2 of these units, and I have gotten at least 5000 hours out of each lamp. Toward the end of the lamp life, it may start getting dim and/or have difficulty starting, but I probably wouldn't replace it until you either notice the dimming or the lamp fails, although I've heard some say they can damage the projector when they fail, I have not had any problems.
Dec 03, 2009 | Sanyo PLV-Z2 Multimedia Projector
My PLV-Z2,globe will not light up,power up to
ballast and/or lamp is bad and needs to be replaced. the ringing sound is high voltage issue.
Oct 04, 2009 | Sanyo PLV-Z2 Multimedia Projector
LCD panel
The part is replaceable thru sanyo and the cost is $600 + shipping.
Sep 04, 2007 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV-Z2 Multimedia Projector Logo
304 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
