1996 Toyota Camry Logo
Posted on Aug 12, 2011
Ok long story short door panel was takin off and it wasn't put back on correctly so my windows, seats, mirrors, locks and moon roof are stuck were they are. I kant move anything that needs power! What is needed to be done? Checked fuses and all that but idk wat else to do! Someone said I need a mother board?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
227
Points
10
Did you check all the fuses even under the hood check the connector at the door panel you removed chances are you have a bad conection or you burned a fuseable link
I have Nissan Quest SE 2004 . The back seat stuck folded in the cargo space. How can l release it?
My third row seat was stuck in a tilted back location. It would have been OK if I had the moon roof option. I took your advice; lowered it down into the well and stomped on it a few times. When I put the seat back up, it was no longer in the tilted back position. Thanks.
1helpful
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Moon roof and power windows do not work. Power seats and door locks till work. Relays and fuses good
Are the switches located near each other? Plug may have come off or on some models with console switches things get spilled in them???
2002 impala water dripping from panel where moon roof switch is, compass, fuel mpg info.
It is going to be the seal in your moon roof. Unless you have holes in the top of your car you can be sure that the water is coming from there.
2helpful
WHAT IS THE FUSE LOCATION FOR THE POWER SEATS
Hi there:
Just two locations there:
Passenger compartment fuse panel
The fuse panel is located on the left hand side of the instrument panel facing the drivers side door.
osition 18 25A - Drivers Unlock Relay, All Unlock Relay, All Lock Relay, Power Seats
Power Distribution box
The power distribution box is located in the engine compartment.
Position 4 30A - Power Windows, Power Moon Roof, Power Seat
Hope this helps, also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
2answers
Sunroof stuck open, think the switch maybe bad
I have same problem. Below are a couple of suggestions from LincolnOnLine.com on how to close the sunroof manually. The first relates to a '93 and I'm not sure about the second. Use this info at your own risk. If you get a better answer, PLEASE POST IT HERE FOR ME. Thanks. Mort
Here is the text from my 93 Manual. There is an access panel in the rear centre of the headliner if it is the same as my 93.
Manual Operation
To close the sliding panel manually, remove the roof access hole trim panel located at the rear of the moon roof assembly. Remove the motor and bracket assembly as outlined to expose the splined shaft of the moon roof drive gear box. Using a typical corporate door window regulator crank handle properly set on the splined shaft, crank the moon roof panel closed.
Motor
CAUTION:
It is recommended that the battery ground cable be disconnected when removing or installing the moon roof motor assembly.
Removal and Installation
1. Operate glass panel until rear of glass panel is flush with sheet metal surface.
2. Remove motor access cover.
3. Remove two motor retaining screws.
4. Lower motor away from splined motor gear and disconnect electrical connector.
5. To install, reverse Removal procedure and synchronize motor as outlined under Adjustments.
Good Luck! __________________
Current:<P>1995 Town Car Executive 80K Miles<BR>1990 Mustang LX 2.3 Auto 62K<BR>1985 Chevrolet Caprice Estate Wagon X 2 (160K & 100K)<BR>1983 Chevrolet Caprice Sedan<BR>1984 Renault Turbo Fuego 60K<P>Past<BR> <BR>1980 Oldsmobile Cutlass<BR>1980 Chevrolet Citation<BR>1974 Triumph Spitfire<BR>1968 Triumph Spitfire<BR>1957 MGA<BR>1966 Renault R8<BR>1966 Renault R10<BR>1974 Chevrolet Malibu<BR>1968 Pontiac Firebird<BR>1966 Honda S600 Converible w Hardtop<BR>1978 Bobcat<BR>1969 Buick Last edited by Thanet; January 8th, 2007 at 07:07 PM. #3 post_old.gif January 8th, 2007, 07:26 PM Bill M. user_offline.gif Registered User Join Date: January 8th, 2007 Location: Boston, MA Posts: 3 reputation_pos.gif Moonroof Woes Thanks for the moonroof help. I might be getting a switch in the a.m. If not that remedy doesn't sound too bad. Bill M. #4 post_old.gif January 8th, 2007, 09:49 PM image.php?u=18244&dateline=1141618175 Tman70 user_offline.gif Moderator Join Date: July 26th, 2004 Location: New York Posts: 2,757 reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gif 1. Remove the roof headlining access hole cover located at the rear of the roof headlining.
2. Remove the sliding roof panel motor as outlined to expose the splined shaft of the sliding roof rail and guide.
3. Crank theroof sliding outer glass panel closed using a typical corporate door window regulator crank handle properly set on the splined shaft.
4. After performing these operations, remove crank handle and retime as outlined. Refer to «Adjustments, Motor Synchronization (Timing)» .
5. Install the sliding roof panel motor.
6. Tighten to 4-6 N-m (36-53 lb-in) and install roof headlining access hole cover. __________________
I went to put down my convertible top and it hit something in the back seat and now it is stuck. I had to manually put it down, the electrical part of it is still not working, Can anyone give me some...
I don,t understand how roof hit something in back seat
If roof is down you need to use special tool located end of driver side dash
Flip of plastic cover to see tool
Check owner manual how to use
The tool will locate between rear seat,this will close and lock rear cover
Make sure both sides of rear cover lock,get friend to press down
Once rear cover is locked down,remove tool,and check opperation
Make sure doors shut and windows down
2answers
1998 mercedes benz e-320 wagon electril problem
Hello.
Your the problem your having with your car is because the CAN controlled area network is down.
The most common component to go bad in your model car is the right rear window motor. If your handy pull the rear door panel and unplug the motor for the window. if thats the cause everything will now be working again.Let me know if you need further help
Thanks
MBTim
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
