Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Hot Point Refrig.
Condensation bowl/pan filling up fast. Have check seals and wiped them down. How else can you check the seals. What else do I need to check? what causes the water to evaporate from the bowl?
    President:
  • 1,462 Answers
This could have been due to leaving door open by accident so excess ice formed. water just evaporates with heat from the compressor
Posted on Sep 05, 2008
Why fridge westinghouse model bj505 keeps filling up drip-pan?
check the fridge doors seals. make sure doors seals against the frame. check condenser and clean by vacuum or bottle brush.
watch out for conderson fan motor
May 25, 2014 | Refrigerators
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
How to add transmission fluid/oil in 2001 lincoln ls? And no I do not want to go to a dealer I want to learn how to do it myself.
HI,
First off, locate the transmission dipstick in engine compartment, will be marked TRANS or something similar. CHeck tranmsmission fluid with transmission hot (after driving a while) engine running, in park on a level surface. The crosshatched area marked on the dipstick is the running range. The fluid amount from lowest point to highest point on dipstick is only one U.S. pint, so you won't be adding much fluid at any one time. In fact, only add a very little bit at a time, wipe off stick, re-insert and check again after waiting a couple minutes for fluid to drain down out of tube. Be very careful not to overfill your transmission, as seal / gasket damage will result.
Fluid is added through the dipstick tube with the use of a funnel. There is no other outside port to put fluid in an automatic transmission. Remember, pull stick, wipe off, re-insert stick fully, pull out stick and read level. Then add very small amounts as indicated, checking level by waiting for fluid to drain out of tube a couple minutes, insert stick, pull and wipe off, reinsert, pull and check....Mike
Jun 27, 2011 | 2001 Lincoln LS
Condensation on ceiling of refrigerator (under the freezer). Ice crystals in small crate. Hot, humid weather now. Thanks! Hana
wipe down the moisture and if there is a switch which says "saves energy" or "reduces
moisture" then turn it on. (this is a mullion heater to reduce condensation) Also check
door seal for gap (this can sometimes be adjusted by light heating with a hair dryer
or replacing the seal itself). Hope this helps.
May 29, 2011 | Amana Refrigerators
Brand new fridge. I have a bad smell like urine comming out from the bottom front. is this a leak.. fridge is staying cold. this smell started a week ago. Fridge is 2 months old
smell is urea,it is a gas produced when plastics get hot,it will go away in time,but also check the drain for a blockage (syringe with clorine bleach)and if fitted, wipe out the condensate pan with clorine
last make sure the door seals fit all round as iif not flush any condensate will drip out from the front bottom.
Aug 12, 2010 | Frigidaire Refrigerators
Water leaking in from freezer into main refrig at the back
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jul 05, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Water is dripping from the freezer compartment into the fridge compartment.
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to vacuum out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze One moment I will send you to a ink and scroll down the page and read and watch movie Click Here=> Sea Breeze Tip's
Mar 13, 2010 | Whirlpool Refrigerators
My kenmore refrigerator isn't getting cold enough
SHORT OF GAS,OR WEAK COMPRESSOR. NEED ENGINEER.
Mar 09, 2010 | Refrigerators
I get a puddle of water inside of the the refrig every a couple days, I have turn off the refrig, and blow with the fan for over 5 hours, hoping that will solve the issue, however that didn't work.
check the seals for leaks. condensation from warm air leaking into the fridge through bad seals collects on the inside. also, if condensation collects on the evaporator coils, it'll freeze. then when it goes into defrost mode, all of the frost and ice melts into a condensate pan under the fridge. if the tube to the pan is blocked, the condensate stays in the fridge. so, check the seals and check the condensate tube.
Nov 09, 2009 | Samsung RS2630SH Side by Side Refrigerator
GE refregerator
this is a drain issue..check to see if you have a plastic drain trap going into back of refrig . its located about middle of rear of box. this is where your water drains out of and down to drain pan. this gets filled with food particles and such and stops up flow of water..remove by twisting and pulling out slightly..clean out and re=install...if you do not have this..go and remove freezer back wall..you will need to open drain and clean out trough under evaporator..use hot water and continue until water flows down into the pan..
Jul 11, 2009 | GE Refrigerators
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
63 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
