Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
Posted on Aug 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing alignment - Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
Anonymous
Level 2:
  • Expert 310 Answers
  • Posted on Aug 12, 2011
Anonymous
Expert
Level 2:
Answers
310
Questions
0
Helped
139156
Points
690
Press Setting button on your computer four times, your printer display "u" and then press black/color. The printer start to print one page. After printing the page put the paper on the scanner port and press black/color... that's it ..... thanks
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
How do i align my printhead on canon iP1200
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. alignprintcartridgesa.jpg alignmentpanther.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
3helpful
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
1helpful
I get a blurry result when printing. almost as if it gets printed twice on the same paper
Hi, this usally is becuase the carttridges are not calibrated/aligned.
To align the cartridges:
(extrated from HP.com)
  1. Open the HP Deskjet Toolbox .
  2. Click Align the Print Cartridges .
  3. Click Align , and the first test page will print.
  4. Examine the test page and follow the onscreen instructions to complete the Align Print Cartridges dialog box.
  5. After completing the Align Print Cartridges dialog box, click Continue . The second test page prints.
  6. Compare the second test page to the onscreen example and follow the onscreen instructions to complete the alignment process.
Cheers,
Ed
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
Score the solution and download the manual if you need it
Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
To align the print cartridges from the HP Photosmart Software
1.
In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
2. Click the Device Services tab.
3. Click Align the Print Cartridges.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
1helpful
I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
Installing print cartridges
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
  2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
  3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
  4. Hold the cartridges with the HP logo on top.
  5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
  6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
  7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
  3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
old marine
old marine
ZJ Limited
ZJ Limited
