How to hook up an amp to a reciever without preouts, can it be done?
I have h/k avr 45 no preamp outputs i want to hook up yamaha mx460 for music only can i hook up through the tape monitor output
  • 10,594 Answers
Yes, you can have output signal at tape monitor output terminal and can be hooked to any amp.
Posted on Sep 04, 2008
How do I hook up 2 preamps for the front right and left 1 for each channel on a Marantz SR6007? Can I even do it or am I just allowed 1 preamp for the fron right and left channel?
Hi Mark,
One can hook-up as many peamps as desired to the SR6007 either as sources or destinations. How to connect external preamps to the SR6007 depends on what you wish to achieve.
The SR6007 already has its own internal preamps.
You could, if you are not careful, burn the AVRs input circuitry by adding external preamps as "sources". Also, not much improvement in SQ could be gained by external preamps connected to the SR6007's preouts becuase any signals that come out of these have already been processed (or distorted?) by the SR6007s internal preamps.
Jul 31, 2016 | Marantz Audio Players & Recorders
Yamaha ax470 amplifier, power amp works but nothing else
This unit has main in, preout jacks. When you say the amp works, are you referring to the amp turning on? There will be no sound out of the amps, if there is no preout. Are you aware that there needs to be jumpers between the main in and preout jacks? If you don't have the jumpers, no problem; just use a stereo patch cable between the jacks above.
May 08, 2014 | Yamaha Audio Players & Recorders
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Hooking up Turntable to Yahama HTR-5660
you have to have a pre amp, or an old reciever with a phono input.
you dont have to use the aux input, the cd or md-cdr inputs will be fine, but you do need that preamp for that reciever
Nov 29, 2008 | Yamaha Audio Players & Recorders
Sub output
With RCA cables. Just plug into the preamp outputs on the back that are labeled for "subwoofer" and run them to your amp. In your on-screen EQ, you'll have a separate adjustment for the sub (which adjusts that set of preouts, without affecting the tone in the rest of the speakers).
Jul 14, 2008 | Jensen's VM9312 Car DVD Player
1974 marantz model 2325 reciever and want to hook up a powered subwoofer ?
Hi jdwoomer
BEST WAY
Your amp has PreOut and Main In RCA connectors on the rear, you could make up an adaptor cable (or buy one) to split the post vol control signal at this point, and then use line level from here to drive the sub.
OR
Most powered subs have a speaker "high level" input, where the sub "sniffs" off signal from your speaker output. When setup like this the speakers and amp connect to the back of the Sub.
Either way, you can do it... Marantz were making nice gear back then... a collectable these days :) Any questions, I am here to help.
regards
robotek
May 06, 2008 | Marantz PM7200 2-Channel Amplifier
Hooking it up!
If the amp has PreIn PreOut connections, then thats the best way to go. Home theatre amps however, have 5 InOuts, and this makes it hard. You can use the tape loop. Hook up the rec out on amp to inputs on EQ, and output of EQ to tape in an amp, then engage the tape monitor function whilst ensuring that the rec selector has the source you wish to use the EQ for.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
492 people viewed this question
 Grubhead
Grubhead
