Question about E-Machines eMachines Desktop PC
Usb ports not working
Bios is enabled and so is plug and play. but still no junk drive pops up or even recognized.
    Scholar:
  • 152 Answers
Check if the wires connecting the USB port and the mainboard is in place. It may be loose due to transport or troubleshooting activities inside the CPU. Manufacturers usually label these wires. You can access it if you open your computer and look at the back (inside) of the front side of the CPU.
Posted on Sep 08, 2008
Dell 6420 laptop not recognizing USB ports while on docking station
Hello Jackie.
2 of youre USBs are USB 3. so you need to install the right drivers for USB 3.
Also you should check youre BIOS settings, if there is an option to enable "XHCI" support so enable it. (USB 3 needs this to work ).
regards Gue.
Apr 21, 2017 | Microsoft Computers & Internet
Message keeps popping up saying that the USB device is not recognized and then talked about it maybe have malfunctioned, but there is nothing plugged in to any of my USB ports.
Go into the BIOS. Disable the USB ports. Reboot. Message gone? Turn off. Check with flashlight if dustbunny, or foreign oject in port? Reboot- go back to BIOS. ENABLE USB. Reboot. GOOD LUCK!!
Aug 09, 2011 | Computers & Internet
Is there a driver to allow sony micro vault 2.0gb on win 98?
Specs say it is compatible with Windows 98 SE. Also says no drivers are needed for it. Make sure your plug 'n play is enabled on your computer. Once it is enabled just plug the drive in & Win 98SE should install it. If it does not work then try a different usb port as maybe a port is bad. Hope this helps.
Jan 26, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
My laptop doesn't detect the external hard drive
Hi there
hey if you are not getting it to recognizing the drive on system startup use your set up disk if you have it if not go to device manager and scan for hardware change and see if it can be found there if not try going into the bios and ensure that the usb ports are enabled and that the plug and play is enabled also you also need to ensure that the device is compatable with your pc i would check with the manufacture of the computer best regards mike
Dec 13, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
have you booted into bios and looked to see if the usb ports are enabled and that the plug and play is enabled please try that and get back with me ok best regards mike
Aug 28, 2008 | E-Machines eMachines Desktop PC
W4682 desktop none of the usb ports are recognizing anything. i had the power supply changed but it didn't come from an emachine it came from a dell. the old power suppy went out on me but before it did...
you will need to boot into bios and in the periphial device or advanced area it should show the usb devices make sure that they are enabled and not enabled and make sure that the plug and play devices are enabled ok i hope that this is helpful best regards mike
Aug 26, 2008 | Intel Motherboard
"USB Device Not Recognized" - any usb device
Hardware to old or a spontaneous defect ? Burn a free linux live dvd ( mint or other live distro) to recognize a good working device.
Boot on cdrom and see what happens.
DistroWatch com Put the fun back into computing Use Linux BSD
Mar 08, 2017 | Electronics - Others
Unrecognised external drive
Hello Sir,
Here are a few things to try. If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. If it?s still not being recognized, Maxtor has a free utility called PowerMax (available at www.maxtor.com) that lets you run various tests on your drive till it identifies the problem.
Plus another thing to look at is if whether or not plug and play is disabled in the system Bio's. Course the easiest way to see if that is the case is to plug something else like a pen drive into the USB port and see if it is even working. It may also be that the USB port is not working or is disabled, or better yet your system has only a USB 1.0 port. In which the pen drive may work but it is not enough for the Ext. Hard Drive which requires USB 2.0.
But the remedy is to first try the drivers and software, then check to see in your hardware manager what USB you have, then if plug and play is enabled in the BIO's as well as what the USB setting is in the Bio's, and last but not least add a USB 2.0 PCI expansion card and try that.
Plz forget to comment....
Cherrs!!!!
Jan 08, 2008 | Computers & Internet
Usb ports
Make sure that USB ports are enabled in your PC.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
