Invalid ip address - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Describe your problem
Posted on Sep 04, 2008
Where is this IP located 192.168.1.117
I checked your IP address at this site Ip-details.com .Here,it does not display any loction information .I think your ip may be invalid .However you can use above site to find the location of particular IP address.
Jan 04, 2013 | Samsung Computers & Internet
I am stuck I did the renew and got a 169. IP address but still stuck still not acquiring an network.
If you got 169.X ip address, it means invalid IP address. Please check your DHCP server configuration and also try to make it static IP.
cheers
Feb 04, 2011 | Computers & Internet
Ip address in invalid on windows vista
All we need to do is to reset the router for about a minute, if we are still getting invalid IP which is 169.x.x.x then we need to temporarily assign an ip address on the computer.
How to assign IP address:
Windows XP
Step 1: Click Start, then Control Panel.
Step 2: When the Control Panel window opens, double-click Network Connections.
Step 3: Right-click Local Area Connection, then click Properties.
Step 4: When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then Properties.
Step 5: Change the option from Obtain an IP address automatically to Use the following IP address and enter the following:
Make sure the IP Address you'll be assigning the computer has the same first three numbers as the Default Gateway and the last number can be any number between 2 and 99. In this example, our Default Gateway is 192.168.1.1, so the IP address that should be used must start with 192.168.1. In this example, the IP address that we'll assign is 192.168.1.50.
  • IP: "192.168.1.50"
  • Subnet Mask: "255.255.255.0"
  • Default Gateway: "192.168.1.1"
After assign static IP then click OK.
Step 6: If we are not getting any response from the router(like pinging the ip address of the router) then possible product is defective.
Dec 22, 2010 | Computers & Internet
My laptop says it has an invalid ip address
If the laptop's own IP address is invalid, you need to figure out where the incorrect settings are. If you're running it with a wireless adapter and a router, make sure that the network connection is set to DHCP and not to static IP address.
Probably the best course of action, especially if you're not very experienced with networks or IP addresses, is to run the New Connection Wizard, which you can access like this:
1) click on Start
2) move the mouse pointer up to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection
7) follow the instructions.
I hope that helps! Good luck.
Oct 10, 2010 | Samsung Computers & Internet
7940G IP Phone: how to solve the protocol application invalid prob...
Hi
This happens when you IP phone communicated with the Voice vlan with the IP address of data vlan.
To solve it manually enter the IP address of the TFTP server and option 150 on the DHCP server.
remove the voice vlan from the switch port and reboot the phone
again add the voice vlan and reload the phones
May 17, 2010 | Cisco 7940G IP Phone
Cannot connect to the internet wirelessly. says i
If you are getting invalid ip try the following:
  1. Click Start and type "cmd" in search press enter
  2. In the command prompt window type ipconfig /all
  3. Check the ipv4 ip address
  4. If you are getting an ip address as 169.254.xxx.xxx
  5. Go to device manager
  6. Uninstall the Network Adapter
  7. Reboot the computer
  8. Re install the driver for you network adapter if prompted
  9. You should be able to get a Valid ip address and get connected
If you have a pci network card installed
Try to remove the card and install it in another slot.
Hope you find this solution helpful.
Thank you for choosing Fixya.
Jan 22, 2010 | Acer 91.AB370.001 Network Adapter
Cannot connect to open wireless network Invalid IP Address
Either the network requires you to manually configure your ip settings(unusual but not unheard of) or your wireless adapter is not set to get settings from DHCP. Check to verify that your wireless adapter is set for DHCP and if this is correct then you'll need to contact the administrator for the wireless AP and haver them check their settings.
Jan 08, 2010 | Dell Latitude D610 Notebook
IP address invalid
8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
Dec 18, 2009 | Computers & Internet
Says I have an invalid IP address
Go to control panel select network right click icon go to tcp/ip properties and choose get ip address automatically DHCP
May 01, 2009 | Gateway GT4016 Desktop PC
Computers & Internet Logo
David Payne
David Payne
