Question about HP PSC 2355 All-In-One InkJet Printer
Help! i have a psc 2355v and i can't get it to print an image or any words. the paper feeds through and it makes sounds like its printing but no image appears
  • Anonymous Sep 23, 2008
    Brand new ink but it wont print!
    Scholar:
  • 95 Answers
Has it been a while since you've used the printer? If so, it's probably dried out a little. Try a couple things.
  1. Check if you are out of ink. The HP printer software will have an ink level picture indicating how much ink you have in the tanks.
  2. Print a test page.You can do this by click on the start menu, then selecting printers and faxes. Once you see your printer, right click it and choose properties. Then choose to print a test page. If that fails to print, go to step 2
  3. Clean the print heads. In the previous menu, you should find an advanced button. You'll have to search around a little as I don't have this printer, but there will be an option to clean the print heads. You may have to repeat the cleaning multiple times before you start to see an image.
If that doesn't work, comment back and we'll try some other things.
Steven
Posted on Sep 17, 2008
Keeps saying paper jam and paper goes half way through
hi
1. 1 Switch off the printer and disconnect the powersupply. Allow any residual charge to fade away before putting your hands ormetal tools inside the chassis. 2. Step 2 Pin down the exact location of the jam. Thethree hot spots for a jam are the paper tray, anywhere between the feed trayand the print carriage, or between the print carriage and the output tray. 3. Step 3 Take off the front paper tray if the sheet gotstuck while it was still in the front area of the printer. If the sheet jammedhere, you should be able to see most of the paper. 4. Step 4 Pull on the sheet with both hands and steadypressure. Do not tug as you might rip the paper, leaving a chunk of it deeperin the machine. 5. Step 5 Open the back panel to reach paper jammedbetween the feed tray area and the print carriage of the all-in-one printer.Carefully remove the jammed paper from the machine. 6. Step 6 Use the carriage access door to reach a jamfurther inside the all-in-one printer. You may need to move the print carriageout of your way to clear the jam. 7. Step 7 Return any access panels to their closed andlocked positions. Plug your printer back in and flip the power switch.
Oct 31, 2010 | HP PSC 2355v All-In-One InkJet Printer
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Hp psc 2355v printer starts printing. i get error:0xb9000001
It was my windows firewall. went adjusted the print and file sharing on the exceptions tab and the problem dissapeared.
Jun 13, 2009 | HP Office Equipment & Supplies
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Can't print to the edge of the page
I don't know many inkjet printers that can print to the edge of the page on all four sides. The area in which the rollers feed the paper often can't be printed to and neither can the very bottom.
Dec 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Need to reinstall my HP 2355 printer
i lost my desk.. i need help to reinstall my hp 2355v psc all-in-one printer..
Jul 12, 2008 | HP PSC 2355v All-In-One InkJet Printer
Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Jun 01, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
