Question about Maytag Dryers
Maytag neptune mde5500ayw the light inside comes on but nothing on control panel lights, totaly black
  • studhorse Jan 15, 2009
    I have the same problem, the light is on in the dryer but the display is dead
  • 262 Answers
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Posted on Jan 17, 2008
SOURCE: Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
Look at this link... it worked for me!!! Basically,
1) Use a heating pad and warm the display.
2) Open the dryer door as well to let the warm air in.
It took about 15 min for me and saved me a over $100 in repair costs.
http://mikemerrittmotors.yuku.com/topic/796/t/Maytag-Neptune-Dryer-Lights-up-8-8-Wont-work.html
Posted on Jan 02, 2009
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
  • 2699 Answers
SOURCE: How do you open the top of a Maytag Neptune dryer
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Posted on Feb 10, 2010
dayminner
  • 159 Answers
SOURCE: I have a mde5500ayw neptune
There wasn't any info online about how to take off the side panel, but I did manage to find the manual:
http://www.retrevo.com/d/ds/progress?doc=102845c4e47e0767504547155dae7dfe&rk=0.07991090660941469
And inside there was a Maytag Customer Service Assistance Toll-free Number:
America: 1-800-688-9900 begin_of_the_skype_highlighting 1-800-688-9900 end_of_the_skype_highlighting
Canada: 1-800-688-2002 begin_of_the_skype_highlighting 1-800-688-2002 end_of_the_skype_highlighting
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Posted on Jun 04, 2011
I have a mde5500ayw neptune electric dryer that the control seem's to be struck, i need to know how to remove the side panel too check the fuses inside the unit
Hope this helps!
~~Dayminner
Jun 04, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde5500ayw dryer had an oversurge of power earlier, now dryer display is dead but light inside is on. Is there a fuse in dryer?
could be one on the control board, but I will bet if you had an electrical surge theres more than just a fuse gone
Oct 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Light on inside but control panel wont work model MDE5500AYW
why would this site ask me if I solved my problem and if so "click here" to give them an answer on how to fix my problem if this site wants to charge me to get an answer from them?
Mar 23, 2009 | Maytag Neptune MDG5500AW Gas Dryer
the circuit in the control. you can get it at
http://www.apwagner.com/index.php?main_page=part_finder
I hope this helps.
Dec 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
159 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
