Question about Canon Pixma MP800 All-In-One InkJet Printer
Incompatible device detected
When I power on my printer the folowing error is displayed on the LCD scren: Incompatible device detected. Remove the device. There is nothing connected to the printer. I even removed the USB cable to my laptop. Is there a way to reset this?
  • Melisa_RN Sep 05, 2008
    That worked! Thanks so much!
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    sounds like you could have a faulty ink cartirdge, remove them and see what happens
    Sergeant:
  • 359 Answers
Please rate this solution
Posted on Sep 05, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
How To Reset Canon MP276 Error p08 Experts.
Turn the printer is the printer on. And remove the USB printer cable from your computer ..
While the printer is off, press and hold the Start / Stop in the canon of some other models of printers, press the Resume / Cancel.
While holding Start / Stop or Resume / Cancel button, press and hold the POWER button.
When the Power LED (green) lit, release the Start / Stop / resume / cancel button (without releasing the button).
Without releasing the power button, press Start or resume the Stop button or cancel button twice, then release the POWER button. Wait until the printer LCD display 0 (zero) the number of
After the screen is 0, connect the printer cable UDB to your computer, will detect the new device installed (normal), will now restore steps
solution taken from:blogspot
May 26, 2011 | Computers & Internet
Error Message: 104-Unsupported wireless network device detected. System Halted. Remove device and restart.
And when you did that, did the system then work? If it did you may have a faulty WiFi card or an incompatible driver.
Feb 23, 2011 | HP Compaq Presario V2000 Notebook
Hp c6180 will not print from windows vista; no error message displayed on computer or printer; print queue says error printing with no explanation wireless installation hp solution center says no hp...
This means that your system does not display any printer name under the printer's list even though you would have installed your wireless printer on your Windows Vista system. This could be caused if you have not updated printer drivers in your system or the printer is incompatible with Windows Vista. Also see if the Windows firewall is blocking the printer from being recognized by your system. get more information for HP Wireless Printer Problems . Hope this helps you.
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
1. My printer displayed "USB Device Not
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | HP Photosmart Premium C309A All-In-One...
Majenta ink does not print
Incompatible device detected. Remove the device. Remove the cable between the camera and
the machine.
Oct 11, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Leading edge detection error When loading paper into printer this is displayed on the lcd scren
This is caused when the size paper loaded into the machine does not match the size the machine expected. Check the paper size settings to ensure you are using the correct paper setting. This also can be caused if paper loaded does not align correctly.
Jul 09, 2009 | Canon imagePROGRAF iPF8000 Printer
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
Printer won't print
first of all never use a napkin to clean any electrical devices. Napkins can hold a static charge.Plus as you use the napkin little pieces of it could get stuck between the terminals. Add a little moisture and it spells disaster. For the solution what I would do first is unhook your printer. Shut the power off and unplug it. Then go into your add remove programs and remove all the software and drivers for your printer. You will also want to double check its gone by going into my computer and seeing if under printers your printer is listed.Then what i would do is get a registry cleaner there are many of them on the net to download. This will fix any registry problems that could be causing a error. After running the cleaner then reinstall your printer. Make sure you install it like the manufacture has listed,each printer is diffrent on how it is installed. Once you load the software and plug it in use the utilites software that comes with your printer and test a print page.
Sep 04, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
650 people viewed this question
old marine
old marine
