Cell Phones Logo
Posted on Aug 12, 2011
My Huawei U7510 screen is freezing and does not respond to touch. What could be the problem?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
457
Points
My phone problems is freezed code sos and my globe sim was not open here is my number 09153040182 how can i open this
Help
Hi if you need nck code (unlock code) you can visit this site Unlock-Zone.com here you can get the code and unlock your huawei u7510 easily. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
Unlock-Zone.com
Huawei u7510 nck code to unlock my phone, IMEI: 357397031445579 Replay me on [email protected]
You can get nck code for your Huawei U7510 mobile phone from Classicunlocking.com .Here you have to specify your country name,the current network provider and IMEI number of your mobile phone.Then you can get code from them at reasonable cost and unlock it.
1helpful
2helpful
4answers
Nck code huawei u7510
You can get the NCK Code for Huawei U7510 Model Phone at here Wickedunlock and unlock it from network lock easily.
How do I remove the huawei U7510 glass screen digitiser for replacement?
Its a screen protector which will be sticked on the mobile screen. It will be so thnn, please use an sharp stick which will not damage the screen and using that remove the old screen protector. Then remove the sticker from the new protector and place it on the phone screen and stick .
Thanks
I want the lnput nck for Mobil Huawei u7510
NCK code Or Network Unlock code all are same Only.You can get the Huawei U7510 Model NCK code from here
Theunlockspot.com
and get the Unlocking instructions there or follow it below and Unlock it step by step..
Huawei U7510 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Huawei U7510 mobile phones. If you enter over a certain amount of wrong unlock codes on your Huawei U7510 mobile phone, your phone may get hard locked and sometimes become unusable.
If your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
2helpful
3answers
My Huawei U7510 touch screen does not work
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care
Jun 12, 2011 • Cell Phones
8helpful
10answers
21helpful
13answers
Need an NCK code for an Huawei U7510 IMEI 357397030009913
give the nck code for my huawei u7510 mobile
imei: 353323030116114
Dec 25, 2009 • Cell Phones
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
