Question about HP Photosmart 3310 Printer
Hp 3310 error
Hello Rakesh,
I have seen your help with the fix of a problem with hp printers, and I wonder if you could help me out with my issue.
Today I have replaced the blank ink cartrige on my 3310, after that the printing was not totally ok. It printed 3 or so pages ok and then the ink was fading in horizontal lines on greyish tones.
Tried to find a solution for it and came up with a reset of my printer.
After that a message on the display said I had an scan problem and could not print, copy, scan, send or receive faxes.
The autocheck status showed the black ink printing in light blue.
Well, now I can't do anything. It won't print and gives me this error message:
Ink system failure.
Can't copy recieve or print fax.
Refer to the product manual.
Error 0xc18a0201
I am totally desperate as I see this is a common problem for many users but I have not find a single solution to it.
I have tried yours but as soon as I go to step# 2 the display shows "information menu" and I get lost from there.
Do you have any idea, suggestion or help that I could use?
Thank you very much for your time and effort to help others.
PS, please if you can give me a hand email me at infernational@yahoo.es
I have just registered to this site and I am not sure if I will be abe to get messages from here.
Thanks in advance.
  • 234 Answers
Thanks for trusting me sionah
Please do not go as per the error message you get.
Because the error message means a lot, like the error message you have 0xc18a0201, as per this message the unit has to be replaced (As i have worked with HP i know which error message has to be replaced or can be fixed)
But you can try this steps once. and i would not garauntee to fix your issue, But Better to give a try.
First of all unplug the power cord from the All-In-One from the printers end aswell as the power outlet.
Leave the cable unpluged for atleast 1Min.
Then connect the cable direrctly to wall outlet without the surg protector. and then connect it back to the All-In-One.
If the message is still there.
Press the # and * key in the All-In-One (The Display will say enter special key Combo)
Then press no 1, 2 and three.(The display will give some information) Ignoge the display.
Press the right arrow key till you see System Configuration Menu> Then press “OK.
1. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
2. Press and release the “OK” button.
3. Display should say “Hardware failure status: Clear. Press OK to clear”.
4. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
5. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
6. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
7. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
8. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
9. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
10. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
"PLEASE TRY TIHIS RESET ONLY ONCE"
If ir reoccures replace the unit. you can call HP and get the unit replaced. if it is Warranty.
If not you can also go for a Out Of Warranty Upgrade Option.
Good Luck
Posted on Sep 06, 2008
  • tcf_chd May 05, 2011
    hi Parmod
    Seing your expertise in HP printers I could not resist in asking you the question on my HP Printer Problem which is that I bought a HP Deskjet 2050 3 in 1 from Dubai with the original cartidges being 122 but in INdia only 802 no cartridges are available . While getting online help from HP they told me to get the printer regionalised from the local service center but the local guys tell me they would not do it as it is a new launch so PLEASE HELP otherwise my printere worth 4k and cartridges worth another 1k will have to be dumped WAITING FOR YOUR ANSWER THANKS in ADVANCE
Ink system failed 0xc18a0001 3310 all in one
Hi, Please go to this website and follow the steps.If it will help you to fix your issue then fine Otherwise you need to contact with HP to get the issue fixed:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&cc=us&dlc=en&jumpid=reg_R1002_USEN&lc=en&product=1153491
www.ittechsupportonline.com
May 07, 2012 | HP Photosmart 3310 All-In-One InkJet...
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
Error 0xc18a0301
Hello Alina,
Please Click here and follow the instructions to resolve this issue.
Regards
laxman
May 26, 2009 | HP Photosmart C7280 Printer
HP Photosmart Printer 3310 offline/can't configure
sure..it's possible...and it's an automatic when installed..follow the installation disk instructions
Jun 18, 2008 | HP Photosmart 3310 Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP 3310 All In One Error
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Oct 31, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
1,390 people viewed this question
Seeker5211
Seeker5211
