Garden Logo
Posted on Aug 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Kelly
Level 3:
  • Master 3,740 Answers
  • Posted on Aug 12, 2011
Kelly
Master
Level 3:
Answers
3740
Questions
Helped
2161890
Points
12091
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
1helpful
I installed a 632690 carburetor on my older sears 10 hp riding mower. The mower starts but I can't adjust the speed. I need a diagram on how to connect the linkage
interesting
Tecumseh 632690 - Carburetor
if still original
the sear should have a Tecumseh 11 hp motor
the pictures are the original governor and carby set ups for a sears 10 hp
Spring and linkage came off tecumseh motor
Contact a Sears parts and service center or Google to see if can find a service manual (exploded view of unit).
Replacing a tecumseh carburetor on a toro
PartsTreeRepairClinic may have a video
Jan 30, 2018 • Toro Garden
2answers
Need exploded view of carb n governor linkage n spring location
the govenor spring fits in with the throttle linkage and the other end goes in the govenor...good luck
Nov 07, 2009 • Garden
2helpful
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
When i start the mower the engine just revs all the way up. i think the governor is stuck wide open any suggestions
Sometimes crud and gunk build up on the carb ,carb linkage and governor linkage, preventing free movement of those parts. First I would clean all linkage points with a spray can of carb cleaner, and then lubricate these points with WD40 or some other lubricant. It's also a good idea to lubricate the control cables and controls.
Jul 27, 2009 • Garden
Top Tecumseh Garden Experts
john h
Ngoro
superjulimaximo
superjulimaximo
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
