Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
THE TOP OF MY SCREEN HAS A WAVE GOING ACROSS AND DOWNWARD WITH GREEN BEING THE PREVATLENT COLOR AND SHOWING DOUBLE VISION TO FACES, NUMBERS AND LETTERS.
  • 927 Answers
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Posted on Sep 06, 2008
TV HAS A RED WAVE ACROSS THE BOTTOM CAUSING DOUBLE VISION
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Panasonic PT-56TWD63 56 in. Rear...
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Televison & Video
Double images
Convergence amps bad call a tech make sure he does'nt use generic parts A Toshiba service center should know what to do around 300.00
Apr 12, 2009 | Toshiba 50H82 50" Rear Projection...
Distorted colour
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 07, 2009 | Hitachi 50UX57B 50" Rear Projection...
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
247 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
