Question about Toshiba e310 Pocket PC
Cant turn my toshiba e310 on
My ppc was frozen and now i cant turn it on !! the reset button doesnt work and the battery was not empty . so? HeLLLLLLLLLLP
Charge the battery for a long time and then go to the battery capacity screen. When the 100% show 100% charge, unplug the charger while leaving the battery capacity percentage screen on. Then you will see 100% again. I had this problem and figure a way to fix this problem. Now I have another problem. 8(
Posted on Jun 12, 2007
There is a white lever on the bottom, you can switch it to reset the unit
Posted on May 11, 2007
  • Len Cahoon May 11, 2007
    i replaced the battery because it said it was bad, now it save it is only charged to 15% Is the a way to clear so it will charge the rest of the way?
I am having the exact same problem. What the heck is going on. All of a sudden it was working fine until I went to use it the next day it wouldn't turn on. I had to manually flip the reset switch near the bottom. Even now I have to do that every time I want to use it. Basically it is unusable until I figure out what it is. I am wondering if the flash memory is getting worn out. I think you can only write to them a limited number of times.
Posted on Feb 04, 2007
    Master:
  • 551 Answers
Your suggestion to pull the battery cable works great. Problem is that even after this method of resetting, when I turn off the PDA, it still won't turn on again unless I follow your reboot procedure. The battery is good. I hope you can help--my Toshiba has been good to me till now.
Posted on Sep 19, 2005
    Master:
  • 551 Answers
The only solution that I found was a hard-reset... Simply remove the back cover of your Ppc removing the four little screws located on the cornes. Then disconnect the battery plug which is a rectangular white plastic piece with four red and black wires. Hold on for about 10 minutes. Plug it again and put the back cover... BINGO!!! The only little problem is that you just lose all your data... so, unless you have a backup (if you are using MS Outlook in your desktop system you have one) you will be prepared to type again all your data.. Good Luck.
Dell e310 won't start after power failure ,orange
First up, don't buy a Dell again unless you like old **** with horrible support.
On Topic
- Did you pull out the keyboard and try another USB port (if it is an USB keyboard), or try another keyboard.
- If that doesn't work try clearing the CMOS (remove power plug, power on (to empty capasitors), either remove the CMOS battery and power on, or find a jumper to reset the CMOS. (since this is a Dell a that might not exist but check the manual).
Jun 25, 2011 | Dell Dimension E310 PC Desktop
My pocket pc e310 wont turn on. i only have the cradle and no ac charger. i have unplugged the battery for a reset but nothing happens after i plug it back in. when plugged in to the cradle, there are no...
The e310 can't use USB power to charge through the cradle. (It needs more than USB specs allow.) You have to supply +5v DC to the connector at the cradle or the e310 itself. Positive terminal is the center pin/hole, negative terminal is the outside barrel of the plug.
Jun 02, 2011 | Toshiba e310 Pocket PC
Mogul Screen black
Press the soft reset button located right under the SD mini memory card its a small hole just press there with your stylus (pen)
Oct 26, 2008 | HTC PPC-6800 Smartphone
My toshiba e310
Did you try the reset button?
Have you tried reflashing the firmware? OS?
j
May 18, 2008 | Toshiba e310 Pocket PC
E310 pc screen not functional
I charged the my e310 pc up and the touch screen doesnt work, but does light up, etc.
Sep 12, 2007 | Toshiba e310 Pocket PC
Stuck with my creative zen
There's a little area at the bottom that says, reset, you take a thumbtack, and just pop it in! It will be back to working condition without losing files with no problems!
Feb 06, 2007 | Creative Labs ZEN Vision:M Digital Media...
Toshiba e310 no reset
When it is reset the screen is just a series of vertical lines or just plain white. if it beeps it isone quick beep.
It appears to do things when you move the stylist over the screen yet can't go to the main screen.
I have followed factory reset (switch off then on), (reset power till screen on then release power), (disconnect power plug from battery to board). NOTHING worked
Jan 24, 2007 | Toshiba e310 Pocket PC
My Toshiba e310 turns on by itself
It could be a piece of software that you have recently installed "activating" your PDA. I had this problem after installing a program that, amongst other things, monitored battery life. Once i uninstalled it it was fine so whether that was just a big coincidence i dont know.
Sep 15, 2005 | Toshiba e310 Pocket PC
My PC not turn on
Toshiba Pocket PC e310 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (19 of 104).
Sep 08, 2005 | Toshiba e310 Pocket PC
Toshiba e310 Pocket PC Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
