Question about Konica Minolta DiMAGE E201 Digital Camera
Change the image quality
Why can?t I change the image quality or the image size of each frame in a movie?
    Master:
  • 425 Answers
This specification is carefully determined to balance between possible time lapse to create smooth motion and actual data processing ability of the hardware.
Posted on Sep 19, 2005
Some photoshop photos does not fit in pinnacle in monotage window how can i solve this??
Return to your editing software and resize the images. If you can establish the maximum size that pinnacle monotage will accept, then all you need to do is change the size to make them fit.
The menu command in Photoshop is Image> Image Size. When the Image Size window opens make sure the 'Resample Image' option is ticked. You then have the option to change the size by Pixels or Percent in the top half of the window or dimensions in the bottom half of the window.
My advice would be to alter the resolution to change the size. To do this you must remove the tick against 'Resample Image' and then change the resolution value altering the value until the size you want appears in the document size area of the window. This way you do not loose any data from the image, retaining all the original quality.
Dec 19, 2013 | Pinnacle Computers & Internet
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
Grainy movies
Go to menu and select images quality
There are three settings for quality, SuperFine, Fine, and Normal. Movies can be capture at 640x480 and 320x240 at 30 fps and 15 fps.
Jan 24, 2009 | Canon PowerShot A620 Digital Camera
Need to know how to use the scanner on a lexmark 6500
You can change the resolution (dpi) of an image or of the copies you're making from the 6570. Here's instructions on how to do both:
Change the resolution of copies:
1. From the operator panel of the printer, press Copy Mode.
2. Press the menu button.
3. Press the arrow buttons until the Quality option appears.
4. Press the check to select Quality.
5. Press the arrows until the quality you want appears (you can't choose a specific dpi here, but you can adjust the quality).
6. Press the check to select it.
7. Press Start Color or Start Black.
Change the Resolution of an image:
1. Open Productivity Studio.
2. Click File > Open and select the image you want to edit.
3. Click Advanced.
4. Click Image Resolution/Size.
5. Select Photo Size to select from a list of defined photo sizes, or click Custom Size to enter a different size.
6. If you select Custom Size, type the width and height you want to use for the custom size.
Jan 19, 2009 | Lexmark X6570 InkJet Printer
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
How many images can the DiMAGE A2 capture using a 256MB memory card ?
In general, storage capacity depends on which image size and quality you have selected. For your information, here is the number of images recordable in a 256MB Compact Flash in the respective image size and quality. Since the image size may vary depending on scenes and subjects, these are approximate values only. Image size 3264x2448 / 3264x2176 / 2560x1920 / 2080x1560 /1600x1200 / 640x480 Std: 106 / 118 / 167 / 243 / 381 / 1043 FINE: 61 / 69 / 99 / 146 / 235 / 781 X.FIN: 31 / 35 / 50 / 75 / 124 / 594 TIFF: 10 / 11 / 17 / 25 / 43 / 245 RAW and JPEG: 15 / 16 / 17 / 18 / 19 / 20 RAW: 21 Movie : Image size 544x408 / 320x240 Movie(15fps) : 7 min. 9 sec / 13 min. 44 sec Movie(30fps) : 4 min. 15 sec / 7 min. 3 sec
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE E201 Digital Camera Logo
27 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
