Question about OfficeMax 0M96431 Shredder
OM99733 15-SHEET SHREDDER
BROKEN SEVERAL TEETH ON MAIN NEYLONGEAR WHEEL, WHERE I CAN BUY THIS PARTS???
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
My shredder has the sound like it is working, but it is not shredding.
From your description, it sounds like when you insert the paper the motor turns on, but the paper is not pulled into the shredder, indicating the two shredder cylinders are not turning. The most likely cause of this is a stripped (missing teeth) main nylon gear. These can be replaced but require some effort.
Apr 17, 2014 | Royal Office Equipment & Supplies
Gears won't turn in forward like a gear or shear pin is broken looking for a service manual
The plastic gears on either side of the drive motor have the teeth sheared off. I just have to find somewhere to buy the parts.
Dec 01, 2009 | Destroyit 4002 Shredder
Broken teeth on main gears
call Fellows at 1-800-955-0959 to see if replacement parts are available.
Nov 11, 2009 | Fellowes 088-32602 (Cross-Cut) Shredder
Broken spacers and damaged teeth
Assuming this is a Royal shredder you can call Royal at 1-800-524-0799. for parts assistance.
Oct 06, 2009 | Office Equipment & Supplies
Broken plastic teeth
I suggest you just go buy a new shredder, otherwise, if you really want to fix it. That would cost you more then you go buy a new shredder.
May 03, 2009 | Fellowes 3011001 Shredder
I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Apr 05, 2009 | Fellowes PS60C-2 Shredder
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Jan 19, 2009 | Intimus 385 se Shredder
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
OfficeMax 0M96431 Shredder Logo
574 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Randy Schumann
Randy Schumann
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
