Question about Whirlpool Washing Machines
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out to fix it. My mother had a whirlpool for over thirty years..so did my grandmother..NO PROBLEMS IN ALL THOSE YEARS!!! Are you people making these machines in China???????????????????
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    The common cause for this symptom is a lid switch malfunction. If you are slamming the lid, you're only making the problem worse. The switch is not designed for that kind of abuse. If you are in the habit of slamming the lid, or placing items on top of the washer lid, this shortent the life of the lid swtich because it can bow the lid to the point where it doesn't make proper contact and/or break the switch. The lid switch in the new models is the same part as what the older models were manufactured with.
    Genius:
  • 1,028 Answers
Ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Posted on Sep 05, 2008
GTUN275EM1WW washing machine filled w water then stopped working no power but dryer work
If this is a top loading washer I will bet the little switch that is activated by the lid when it closes is either loose or broken. Same thing happened to me and all I had to do is tightened the screw on the washer lid that holds on the bar that hits the switch. Look for this bar near the hinge side of the lid in one of the 2 corners (probably the left one).
Sep 26, 2015 | GE GTUN275EMWW unitized spacemaker 3.4 cu....
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
Top load Ge washer model number WVSR1060A1ww will not spend after rinse cycle, open door and pressed lid switch and washer would spin as long as pressure is applied to switch, close door and washer will...
There can be many reasons and i will do the best to cover everything that can happen with your washer to cause it from not draining or spinning. I will attempt to cover the basic things that can happen with washing machines.
First thing to check if your washer is not pumping or spinning is to see if the motor is running. If themotor is not runningb>then check the lid switch. When the lid gets slammed it hammers that switch and eventually will bend it or break it completely. Some washers will wash but not spin or pump, others will do nothing. This switch is located under the lid on the edge of the frame around the lid. Often there is a hole that a pin from the lid will go through and push on a lever that is the switch. Check that it is not simply bent, so that it does not trip the switch inside anymore. To change or check the switch the top will need to be raised or the front removed. Getting to it, is often harder then the replacement.
Thank You, Mike Here is also My personal Sight to Help with other problems you might have as well.
Oct 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
A humming sound in the cycle knob
Make sure that the room is quiet then check that there is a clicking noise from the lid when it is nearly closed
If not then the microswitch is out of whack and needs adjusting
When you slam the door down it is probably enough to make the switch but then the machines movement will undo that action
Jun 02, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Washer will not complete rinse cycle and will stop.
it is probably the piece that your lid pushes down to let the washer know that it is closed try hitting the lid realy hard.It happened to me i have to do it every time
Feb 11, 2008 | Estate TAWS800JQ Top Load Washer
Washer won't start after lid is shut, if i slam it, it works!
sounds like your lid switch is loose ..look at the tab that sticks out of the lid and watch where it close's. inspect the switch see if it is loose or broke
Nov 28, 2007 | Washing Machines
Washing Machines Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal De
