My flamerite atlanta fire will not switch on. When i do turn the heat on the fire cuts out
  • percy321 Jan 03, 2009
    lights flash on fire, then relay clicks on, lights on flame effect on, select heat, then full heat relays click then fire switches off after a few seconds, dependent on attempt to whether fire switches on at all, to get 1kw heat out, 2kw no chance
  • Anonymous May 04, 2009
    same problem but now after having this problems for aome time the full unit does not wotk . So no fire and no light either.
Similar thing happened to mine at weekend after fitting a new hearth and fire surround (sods law) think its the heater unit £57.50 from flamerite
Posted on Sep 15, 2009
Hi ive just moved in a new house and they have a flamerite fire model ha-105 35-10swna halolite.the fire turns on with the lights but ehen you turn the fire off it still blows hot air and cannot have just the lights on dimmer please could you tell me whats wrong also do you have any instructions to this model thanks kind regards julie
Posted on Oct 07, 2010
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
I have a flame rite fire model number 172/180 will not work do you still have these fires
Maybe your circuit board is fried too? Circuit boards come up as issues more than a few.
Kind Regards,
Scott
Need circuit board flamerite 172 180 elect fire
How to fix flamerite fire
Feb 10, 2015 | Home
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
I have a flamerite mercia electric suite, just over 2 years old. The remote control does not now operate the heat function. I have replaced the battery but it still does not work. Any help for a...
I have the same problem phoned the makers Flamerite and they sent me some instructions that may solve the problem. Phone them on 01543251122 I did speak to the shop where I purchased the fire and they told me that this was a common problem with these fires. This did not fix my problem. I will be contacting them again tomorrow. Good luck
Oct 04, 2011 | Heating & Cooling
Our flamerite odyssey fire has stopped blowing out heat and we have changed the thermostat which seemed to be the obvious solution, but it just now blows the fuse.
I may of had the same problem, when i turned on the fire with the remote it would turn off straight away or not turn on at all. However i have just got it working again. Open the the door so you can turn the switch on and off. If you look in the opening where the two bulbs are, there is a small gap on the left. Make sure the mains is turned off, if you have small enough hands put your arm through the gap and push in the connector that is on the back of the on/off switch. My fire has not been working for ages, now that i have done this, it is working fine again. Good luck.
Nov 20, 2010 | Heating & Cooling
I have a Flamerite Odyssey Suite Electric Fire approx 5 yrs old. The thermostat no longer works and I cannot find anyone that sells a replacement. The thermostat only has the number 143211 256-C...
I have just tried to obtain a stat for this same fire Flamerite was no use at all.I have put a link in where the sta was to override, it's on full now, but theres heat now. Terry Risley Electrical Services 0788 4061406
Oct 24, 2010 | Universal Remote Control Heating & Cooling
Breakdown with Flamerite Corello FO1
my Flamerite Corello fire does not work we had to have the circuit bard fixed within the first 12months of getting it and it went again over a year ago how can i fix it
Aug 15, 2010 | Heating & Cooling
I have a Flamerite fire, model is called Isis. The fire come with a remote control which you use to turn on the lights and the heat. The fire is not working, when you press the remote the bulbs on the fire...
Hi I have the same fire with almost the same problem, I even bought some new batteries for the remote thinking that may be the problem.
I bought my fire suite second hand ,(Vega suite with Isis inset) in almost new condition and absulutely love it, so am gutted it has stopped working , Someone said , ''It could be the hidden bulbs at the backof the isis inset that need changing, But on trying to find access to the bulbs I just cannot find a way to get to them, There is 4 screws on the near inside which previous owner has cross threaded and wondered if that is the only way to get to them, If you have any ideas I would really appreciate your help and will contact you also if I can find a solution, Take care have fun
Maureena
Dec 14, 2009 | Dryers
Heating & Cooling Logo
1,763 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
