Question about Nikon D70 Digital Camera with 18-50mm Lens
Need help to unlock the AF-Point
This is a newbie question and need help for my 1 day old D70. While experimenting with the various settings, I realized that I have accidentally locked the AF Point at the right hand side of the viewfinder. Tried to get help from the manual on how to unlock it but can?t seems to find the right page. Other things I tried are, power-off and on the camera, switch from spot focus to dynamic focus but none of them help. Please help.
    Sergeant:
  • 255 Answers
Below the thumb pad there is a lock switch. Make sure it's in the upper position then tap the shutter button. You should now be able to select your focus point. When in doubt press and hold the "BKT" and the "Meter" buttons simultaneously for 3 seconds. Both buttons have a green dot next to them. This will reset your camera to default settings.
Posted on Sep 19, 2005
I have Nikon af s 300mm f2.8, it only work with D3s, D300s but not with my D70. Can you tell me why and is it lens problem or camera
Hiyour lens should be af-s 300/2.8 vr.. nikon product are all compatible. which means your d70 something wrong I think. If you have bundle lens with d70, you can check it out easy. usually d70 comes with af-s 18-55 which is pretty much same work method with af-s 300. THanks and best regard!
May 26, 2011 | Nikon Cameras
How to get several focus points in a d7000 viewfinder?
Hi, On the D7000 you need to press the button on the side of the camera that's in the middle of the AF/M switch and then you use to switch to decide whether it's in 1 point autofocus (hence forth called AF), 9 point dynamic area AF, 21 point dynamic area AF, 39 point dynamic area AF, 3D tracking AF or auto area AF. If you need more help with switching AF modes let me know and I can help you out =)
May 16, 2011 | Nikon D7000 Digital Camera
Is it worth selling mu 5 year old D70 camera (in good working condition) and buying this model?
I would say no. Why bother to sell one old discontinued camera just to buy another discontinued one? The D60 adds very little in the way of new features to the D70 (automatic sensor cleaning may be the most major one) and removes one very important capability (the ability to autofocus with non-AF-S lenses). If size and weight are a major consideration, then the D60 is smaller and lighter than the D70. But so are the newer D3100 and D5000.
No, I really can't recommend moving up to a D60. Nor can I really recommend a D3100 or D5000. Bear in mind that the D70 is a midrange DSLR. The D60, D3100, and D5000 are entry-level DSLRs, more suited to photographers with no experience in DSLRs. If you really must move up, I'd suggest the D90 or perhaps the D7000 (not the D700). But if the D70 is still working for you, you may not need to move up at all.
Nov 02, 2010 | Nikon D60 Digital Camera
Problem with new D90 and old Nikkor 18-200 VR lens
Try a diff lens on the D90 to see if its the body or the lens. Tony
Apr 12, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
I can get my 50mm lens to work with my d70 nikon.
If the lens has an aperture ring, make sure it is set on the largest f number. Make sure the lens is mounted fully on camera. Oherwise an AF 50mmm f1.8 lens should work on a D70 with no problem
Oct 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Hallo!I have nikon F-4 with all range AF lences .I would like to know which model from Digital series D I can buy to use my AF old range of lences?
The Nikon DSLR with the screw mount motor can be used. The older D50 and D70/D70S, D80, D90, D100, D200, D300/D300S and the pro series D1H, D1X, D2H/S, D2X/S and D3/S can use the AF lenses in A/P/S/M model.
Hope this helps,
Andrew
Oct 01, 2009 | Nikon Coolpix 8800 Digital Camera
Re: poor focus problem
usandy,
You can set the focal point by toggling the menu switch (you can see it moving around into different locations as it "wraps" around the viewfinder, now depending on your f-stop the area that is not in focus will be soft, you can also experiment with the autofocus lock on you subject and evn try amnually focusing on your subjects.
randy320sgi
Jul 21, 2008 | Nikon D80 Digital Camera with 18-200mm...
It wont focus or take pictue
Hey harleymomma,
If the d70 is set to AF-S mode focus has to be achieved for the shutter to be allowed to take the photo. In some exposure modes the aperture must be locked down on the smallest aperture. I would also make sure the contacts are clean that allow communication between the body and the lens. Of course you need to make sure the body and the lens are set to autofocus. If none of this works I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 20, 2008 | Tokina AF 80-400mm f/4.5-5.6 ATX840AF...
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
