Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Hey Watch IT!!!!
I already posted a good link while you place held the following and then put the exact same link in.
http://www.fixya.com/support/t1007754-looking_online_pdf_manual_phillips
  • Benjamin Patri
    Benjamin Patri Sep 04, 2008
    nothing wrong? Place holding??? The first link does not have a manual, so you posted BS since philips.com has nothing for a manual proving that you are placeholding and not even posting relevant information
    Genius:
  • 3,422 Answers
Sorry BG but i saw your post only after posting mine.
I have not done anything wrong.
Posted on Sep 04, 2008
I think a good dose of maturity would go a long ways towards helping the BOTH of you! Embarrassing...
How do I change batteries on a M.Z. Berger AW 213 watch
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Apr 28, 2014 | Bulova Watch
Hey there, got somehow on some setting just
You can do exactly as you did to setup Fix, but instead of choosing [6:Fix], select [8:Norm].
To reset the calculator to the default configuration, you can do as follows:
Dec 05, 2010 | Casio fx-300ES Calculator
What if my small slide over the battery has come off completely? how do i put it back?
It should slide into/under a slot from the side, and be held in place by tension (not familiar with the exact model, so bear with me...). Some covers are held in place with a screw; you'll know this is the case if one end has a hole in it. Eyeglass screw kits are a good source for tiny screws. Hope this helps!
Sep 29, 2010 | Movado Museum Esperanza 604122 Wrist Watch
Hey there, I just got an Oniss white ceramic watch for my birthday and I raced out to have links removed. No one can do it - two fine jewelry stores and one watch repair place. They said the don't have a...
Wow. Unusual for those places to not be able to do it. The only suggestion I can find since you did exactly what I would have told you (jeweler/watchmaker) I would try the following link:
http://www.watchrepairsusa.com/oniss/watch-repair
Sorry. Best I can come up with unless someone else has some ideals. Good luck.
Aug 13, 2010 | Watches
The ink absober is full
Heres a canon link for finding your nearest service centre http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx However, you may want to review the following links - which explain how to do the cleaning yourself
Theres a number of solutions on this link http://www.fixya.com/support/t181480-waste_ink_absorber_canon_ip_1600
This is not your exact model - but maybe useful to watch Theres some instructions on this post on how to cleanhttp://www.fixyourownprinter.com/forums/printer/41279 But Beware of causing any damage
Apr 11, 2010 | Canon PIXMA iP1300 Printer
Ink reservoir full on Canon iP 2600 pringer.
Heres a canon link for finding your nearest service centre http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx However, you may want to review the following links - which explain how to do the cleaning yourself Theres a number of solutions on this link http://www.fixya.com/support/t181480-waste_ink_absorber_canon_ip_1600 This is not your exact model - but maybe useful to watch http://www.youtube.com/watch?v=VVpjqBr7KjU http://www.youtube.com/watch?v=4IrBdw7el2E Theres some instructions on this post on how to clean http://www.fixyourownprinter.com/forums/printer/41279 But Beware of causing any damage
Apr 11, 2010 | Canon Pixma iP2600 Photo InkJet Printer
POD watch battery replacement. No problem removing back of the watch - (waterproof / 4 small screws), however the battery is held in place under a ''cage'' type of cover and not the usual single spring...
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
Feb 02, 2010 | Watches
Exact type and size of battery needed for dell 8200 pc desktop, how to remove the old one and put in new one
the motherboard battery is a standard 3v watch battery CR2032, available at any place you can get watch batteries (Walmart, KmArt etc)
It is held in the motherboard by a small clip. depress the retainer, and pop the battery out, snap the replacement in
Feb 02, 2009 | Dell Dimension 8200 PC Desktop
Setting time on Watch
go to this website follow the instructions for finding your particular watch module located on the back of your watch and enter it in the space provided. This will lead you to a place where you can download your manual and learn how to set your particular watch. here is the link to follow and please leave feed back if it was helpful. http://world.casio.com/wat/download/en/manual/
Jan 29, 2008 | Casio G-Shock G7100D-1V Wrist Watch
Users manuel
The following provides access to a two page operating instructions document this document is titled "Watch Setting Guide".
To access the document you will need Adobe Reader (free)
If needed click the Get Adobe Reader button on the following link
http://www.adobe.com
Watch operating instructions
http://www.bulova.com/dynamic_repository/instructions/593W.pdf
There are some additional manuals that might satisify your needs here too (you probably want Wittnauer at the bottom of the page - includes the one above)
http://www.bulova.com/service/instructions.aspx
Jan 01, 2008 | Watches
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
