Question about Konica Minolta DiMAGE E201 Digital Camera
Image quality when manually
What happens to image quality if I manually select a specific sensitivity setting?
    Master:
  • 425 Answers
High or Normal settings are selectable with the DiMAGE E201 for camera sensitivity. Normal is almost equivalent to ISO 85 and high is almost equivalent to ISO 340. High is useful under dark conditions as the flash range increases (0.6 to 5m), but noise increases with sensitivity as electric signal is more amplified, which may result in coarse image. Please select the rating that best suits your purpose.
Posted on Sep 19, 2005
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
We lost manual and don't know how to set camera to take more than 26 pictures
The information you've provided with the question is not enough to give a specific answer. So please do not rate negatively.
I think that you're only able to shoot 26 images with your Camera.
This may be due to limitation in the internal memory as well as the high resolution you set in the Camera.
Using a higher capacity memory card(EG SD CArd, Memory stick etc) will resolve the issue without affecting the quality of the picture.
The another fact that affect the number of images stored in the Camera is the image size(EG:1MP, 2MP, 3MP, VGA etc. )
Here setting Lower resolution like VGA or 1 MB will allow you to capture more images.
However, in most cases, you cannot capture 26 images in good quality in normal Cameras (it comes around 2 to 5).. So you might be already set the Camera in Less Image size. Hence the available option is using a memory card..
Please get back to me with the exact model # of the Camera. I might be able to give more specific information.. http://www.fixya.com/users/shajanrs
Thanks for understanding..
Jan 12, 2011 | Cameras
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
What is ISO?
It is the Film speed to measure of a photographic film’s sensitivity to light, determined by sensitometry and measured on various numerical scales, the most recent being the ISO system. Relatively insensitive film, with a correspondingly lower speed index requires more exposure to light to produce the same image density as a more sensitive film, and is thus commonly termed a slow film. Highly sensitive films are correspondingly termed fast films.
ISO numbers usually double up, and each step gives one more stop of light. Common numbers are: 50 – 100 – 160 – 200 – 400 – 800 – 1600 and higher.
Take a look at these links for some good explanations of what ISO is in phtography.
http://www.all-things-photography.com/iso.html
http://www.photography-tips.co.uk/?p=35
http://en.wikipedia.org/wiki/Film_speed
http://www.ophrysphotography.co.uk/pages/highiso.htm
http://www.videojug.com/film/digital-photography-tips-iso-and-light-settings
Nov 07, 2009 | Olympus Camedia C-8080 Wide Zoom Digital...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Need to know how to use the scanner on a lexmark 6500
You can change the resolution (dpi) of an image or of the copies you're making from the 6570. Here's instructions on how to do both:
Change the resolution of copies:
1. From the operator panel of the printer, press Copy Mode.
2. Press the menu button.
3. Press the arrow buttons until the Quality option appears.
4. Press the check to select Quality.
5. Press the arrows until the quality you want appears (you can't choose a specific dpi here, but you can adjust the quality).
6. Press the check to select it.
7. Press Start Color or Start Black.
Change the Resolution of an image:
1. Open Productivity Studio.
2. Click File > Open and select the image you want to edit.
3. Click Advanced.
4. Click Image Resolution/Size.
5. Select Photo Size to select from a list of defined photo sizes, or click Custom Size to enter a different size.
6. If you select Custom Size, type the width and height you want to use for the custom size.
Jan 19, 2009 | Lexmark X6570 InkJet Printer
OLYMPUS FE-340/X 8.0 MEGAPIXESL
Hey bljack,
There are two main causes of grainy images with digital cameras. The first cause could be that the image size is set too low. I would have it set to the highest size and quality possible, because you can always reduce an image size but you can never make the image size bigger. A list of the possible image sizes are on page 21 of your camera manual. The next main reason for digital noise is having the ISO set to high. ISO is the sensitivity of the digital sensor, and the higher the sensitivity the more digital noise that will be in your images. I would very rarely have the ISO set to higher than 400. I have provided a link to the camera manual below. I hope this helps!
http://www.olympusamerica.com/files/FE-320_FE-340_Instruction_Manual_EN.pdf
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Cameras
NikonD200
The symptom you describe sounds like an incorrect white-balance setting when you take the images. Digital cameras are sensitive to the quality of lighting seen when your taking pictures. First thing to try is to manually select a white balance setting and try the photos again. Try google or your manual to find instructions on how to do that. The camera can auto-adjust to some lighting situations, but fails to properly compensate in other situations resulting in the muddy or yellowed images you have seen. There is a product called "expodisc" that corrects for this white balance problem as well. Look it up. David Millier Advance Camera Repair
Feb 21, 2007 | Nikon D200 Digital Camera with 18-200mm...
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Konica Minolta DiMAGE E201 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
