Question about Dell Axim X5 Pocket PC
Socket disconnecting part 2
Ok here is the setup: Dell Axim 400mhz model with 128MB SD card, Socket 802.11b wireless card and Linksys Wireless Access Point Router with 4-Port Switch (BEFW11S4). I have installed the latest drivers for the Socket card and the firmware on the Linksys AP. I am having some issues with the wireless connection staying active, and below are the details to date. So far, emailing customer support has proven slow at best, but hopefully I can get in touch with them this upcoming week or two. Their first email response suggested getting a good IP release/renew program and doing a soft reset when needed to resolve the problems. Issues: Seems to be losing connection with the AP periodically almost like the driver just gives up. I know it has great power save features, but it seems to just go to sleep and not want to wake back up. Sometimes it gets the IP and works for a minute or so then when I click the next link it doesn't comunicate any longer. Sometimes it doesn't get an IP and gets the MS loopback address (169.XXX.XXX.XXX or whatever) and of course that won't communicate either. Sometimes it works well for a bit then seems to lock up the PPC but if the card is ejected, the unit continues to operate, just not with the card. Sometimes it gets the IP but never communicates. Sometimes it works flawlessly. I can't tell much from the green blinking "link" light other than once a second seems to be waiting but not necessarily connected or not and fast blinking is transmitting and receiving data. Tests: No encryption, 40 bit, 128 bit. Tested sitting right next to the AP with 100% signal and upstairs where it is normally used with about 75-90% signal. (On a side note, I have also performed some of these tests at work but with only 40 bit encryption since I can't change it on all of our routers and also, I don't know what all the brand/models are.) Observations: No encryption (open system) seems to yeild the best results as far as connecting and staying connected. My experience has been 95+% with only one failure that I noted. 128 bit comes second with about 75-80% success. 40 bit (which is ideal because that is what we use at work and I can setup my home network to be a seemless transition between the two) is the worst with about 35-50% connecting success. Most of the problems I listed above come in this configuration. Sometimes removing and reinserting the CF card or cycling the power on the unit will solve the problem, but frequently it requires a soft reset. I have tried many suggestions such as AP settings (preamble type to "short", Fragmentation Threshold equal to RTS Threshold, and Authentication Type to open system) with little or no change in connection success. Questions: Am I wrong to expect the Socket card/driver combo to load and connect to the AP EVERYTIME it is inserted or powered on? Why should I have to use additional tools to get the Socket product to work correctly? Why should I have to perform a so
    Master:
  • 852 Answers
Re: Socket disconnecting part 2
I have had similar issues. I cannot offer much help however. I am using the Socket CF 802.11b card on an ad-hoc (peer to peer) network with my desktop (server) and laptop, and right now am having no problems. 3 days ago, nothing would connect. Discovered an issue with one little checkmark in WindowsXP network for my main connection that is shared and firewalled, I believe it was under one of the advanced properties dialogs, but the setting was "enable 802.11p support". After I checked that box, rebooted, and fired up my laptop, I regained a lost connection, and suddenly, out of the blue, the Socket CF 802.11b card that hadn't worked at all for 2 days started working again. Be advised when dealing with Dell tech support....they told me over the phone that I COULD NOT MAKE MY AXIM WORK LIKE THIS. They said I needed to buy an access point/router and related equipment. Not so. I am having difficulty accessing files on the desktop from the Axim, but really don't need to do so anyway. Don't know if any of this helps ya one little bit, but thought I'd throw a response out for ya anyway. And don't forget that Dell tech advice, although typically sound, is NOT always 100% accurate, especially if it is an oriental guy with a heavy accent.... Best of Luck. Sorry to bother you with a useless response if that's what I did here. Hang in there. Sean W. Smiddy, USAF (Ret), Franklin, OH swsmiddy (AximX5-400 (delivered 24DEC2002) Dell foldable Keyboard (waiting for thumboard to become available to those of us who bought the first Axims) SOCKET Wi-Fi CF card; Dell TrueMobile 1184 Wireless Broadband Router/AP; Ambicon BT2000-CF Bluetooth Card from CompUSA - tethered to Siemens S56 GSM/GPRS phone using AT&T/Cincinnati Bell Service w/8MB per month Data Plan.; 2-128SD / 1-64MB SD Cards. Desktop PC Custom built by me. A real screamer for a 1.8GHz system. Hey, it was top of the line when I built it 2 years ago, & still going strong
Posted on Sep 19, 2005
0 characters
3 Points
Is thare a sim slot in dell axim 51v
Musaji Ahmed Hariff,
Your device has two slots located on the top of the unit. The larger slot supports CompactFlash Type II cards. The smaller slot supports Secure Digital (SD) memory cards, Secure Digital I/O (SDIO) cards, and the MultiMediaCard (MMC). All three memory card types are available in sizes from 64 MB to 1 GB or 2 GB. CompactFlash Cards Your device supports CompactFlash Type II cards. Some common types of cards include: • Modem - Connect a telephone line for modem data communication. • Wireless communication - Data communication without the use of cable connections. You can use cards, such as internal cards with Bluetooth wireless technology and 802.11b wireless LAN. • Storage - Save data or install programs on a storage card
You can click the link below to download the online manual for the Axim51v
http://dell.to/1WKDE1W
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 05, 2015 | Dell Axim X51v Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
I have a dell axim x5 and it connects to my pc and internet fine when its on the docking station. I just need it to connect to my wireless internet connection wirelessly....
The X5 does NOT have wireless built in. You must add a wireless card (compactflash or SD) They tend to be finicky so do a little research for one that works well with the X5 first before buying.
Apr 08, 2009 | Dell Axim X5 Pocket PC
WHere can I buy a wireless card for my Dell Axim X3 PC.
Hey,
the pda has 1 Integrated SD/SDIO Now!/MMC Slot
you can buy a SDIO wireless card
Best deal will probably come from ebay have a look here
http://shop.ebay.co.uk/items/_W0QQ_nkwZSDIOQ20WirelessQ20LANQ20SDQ20WiFiQQ_armrsZ1QQ_fromZR40QQ_mdoZ
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Dell Axim X3 Pocket PC
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
Wireless connection
Check to make sure that the wireless key is set to WEP and not WPA. If it is a WPA, then you won't be able to, as the Dell Axim's don't have enough security certificates to access WPA networks.
Feb 19, 2008 | Dell Axim X3 Pocket PC
Wireless compact flash card installation on dell axim 5
Go to Wal Mart and buy a 1 gig SD card----- and then buy a AmbiCom 54G wireless CF card. Works perfectly in my X5.
Oct 30, 2007 | Dell Axim X5 Pocket PC
Internet connection
For x5, you will need either cf wifi card or sd wifi card. If wifi network hotspot is free and internet access is allowed (check with your college's network administrator for information), all you need is be in the range, turn the wifi on and connect to it (there maybe several security settings you have to do on the axim and these can also be obtained from network admin). For paid hotspot, you will be redirected to enter username and password when you ty to access internet.
Sep 19, 2005 | Dell Axim X5 Pocket PC
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
93 people viewed this question
Top Dell PDAs Experts
Joe Lalumia aka...
Joe Lalumia aka...
yadayada.
yadayada.
matt
matt
Are you a Dell PDA Expert? Answer questions, earn points and help others
