Question about Whirlpool Duet GHW9150P Front Load Washer
Knobs I need a new knob for my quietline washer/dryer combo. Its the master knob that controls all the w/d functions
I got one!
Posted on Sep 19, 2008
  • swan2swan
    swan2swan Sep 19, 2008
    I got many parts for quietline washer/dryer combo WD9500, since I took it apart! :)
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
I need to replace a broken knob for a kenmore 24" stacked washer/dryer Model 11108875279
Their are a total of 5 knobs on the control panel for that laundry center i do not know which knob one you need so this link is for the parts breakdown of the control panel http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-11088752792/0582/0152000/P0403242/00001?blt=06&prst=&shdMod=
Gene
Aug 11, 2011 | Washing Machines
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
I am replacing the washer timer and do not unserstand how to remove the front dial knobs FEA831FS
Hello HmKm, You should be able to just pull the knobs straight off the control stems. Once you have them off, there are a couple of screws on the angled section just above the washer lid. Remove them and you will be able to access the washer controls.
Before you go working on the parts, to remove the control timer, please unplug the stacked washer/dryer combo and turn the water offl. Now you can remove the two screws (that are behind the timer knob) to free it from the metal control panel. Depending on your model, there might be another mounting strap inside the unit that holds the timer in place. If so, remove those screws and you shoud be able to drop the timer down and remove the wiring connection plugs and take out the faulty timer. Now simply push the wiring plugs onto the new timer and reinstall.
Close everything up, reversing the procedures above and turn the power back on and the water and you should be able to use the washer/dryer as normal.
Hope you find this Very Helpful and best regards!
PS: I was one of the folks that was trying to conect with your request for a live chat, but the system wasn't responding, so I aplogize for that technical glitch. Anyway, this is what I would have provided you during the chat session, so best of luck to you in undertaking the repairs.
Dec 12, 2009 | Frigidaire FEX831F Top Load Stacked Washer...
What are the possible problems if the control knob seems not functioning?
It sounds as if the the shaft on the timer assembly is either sheered or the knob has lost its grip. Pull off the knob and check it for tightness of fit when refitted...You may just need a new knob!
Oct 25, 2009 | Whirlpool LTE6234D Top Load Stacked...
Dryer knob does not control times or cycles
i can be either the timer , control board or check to see if there is a wire brush runing on the drum this is a sensor and if it is worn down it give funny readings
Jul 29, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Drying operation on WD16BA on smeg dryer
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
Oct 16, 2007 | Smeg WD16BA Front Load Washer / Dryer
Dryer Function
Usually your local sears guy will come look at any brand of appliance, for about 60 dollars. thats just to find the problem.
Jul 31, 2007 | QuietLine WD-9900 Front Load Washer /...
Whirlpool Duet GHW9150P Front Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
