SOURCE: avaya 4610 ip phone--wireless handset?
Yes. EIther the cs50 or cs55. Or the AWH55.
Both are wireless and work great....
SOURCE: Avaya assighning New static IP address after IP address conflict
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
SOURCE: phone going to DHCP mode
You probably need to change the text file that gives the phone its information.
Get a new 46xxsettings.txt file from the avaya website and replace the one in your directory.
SOURCE: we already have Avaya 4610
You have to be fast. When the phone boots up, it will grab DHCP for 4 seconds. During that time you can press *.
Or, you can wait for teh phone to fully boot up and connect to then system, then do it.
Reinstall and Reset TCP/IP (Internet Protocol)
note: if you're using manually assigned TCP/IP settings, take notes as this will reset to the default 'automatically obtained'
