Question about Hitachi Televison & Video
My Hitachi c2514t picture is distorted it bends out at the top and bottom. how do I sort it out
£140 it cost me to get a new convergence module fitted. Common fault with rear projections
Posted on Sep 04, 2008
How to chang rings on a 1985 honda 350r bike
WELL LOOKING AT THE RINGS THEM SELVES THE TOP WILL HAVE SOME SORT OF WRITING OR MARK THE MARK ALWAYS FACES YOU OR UP..START WITH THE BOTTOM RINGS AND WORKING UP TO THE TOP ONE AFTER ANOTHER..MAKING SURE NOT TO BEND OR DISTORT THE RINGS WHILE INSTALLING..IF YOU NEVER ATTEMPTED THIS ID SEEK SOME HELP AND GUIDANCE FROM SOMEONE WHO HAS..THEY BREAK VERY EASILY..GOOD LUCK..INSTALLING INTO THE CYLINDER CAN BE A NIGHTMARE ALSO..
Feb 15, 2015 | Honda Motorcycles
Separated picture, one bright pink, the other bright lime green. The top and bottom of picture is distorted. The center of the picture is the best in all respects.
Please replace convergence output chips in tv to solve this issue, tv has two big black ICs at right side and number is STK392-110, replace both ICs to fix picture problem
Thanks.
Jan 25, 2011 | Hitachi 65SWX20B 65" Rear Projection...
3d look with little bending in bottom left corner of screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | Hitachi 52LDX99B 52" Rear Projection...
There are green and red waves on the top and bottom of my screen and the shapes in the picture are distorted. This is on a Hitachi 43FDX01B
Ur convergence it dead.U know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.Replaced 2 convergence ICS,and all it resistors.Shop will cost u $300 for parts and labors.
Jan 27, 2010 | Hitachi 43FDX01B TV
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
DISTORTED PICTURE
*Screen Looks 3-D
*Colors wont align
Nov 02, 2008 | Akai PT4298HD Rear Projection Television
Screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
Apr 25, 2008 | Hitachi 53SDX89B 53" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi big screen tv
Convergence IC's bad==replace and then
re-check alignment
Oct 16, 2007 | Hitachi 46F500 46" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
