Question about Whirlpool Refrigerators
WATER & ICE DISPENSER HAVE ALWAYS STAINED A DIRTY RUSTY STAIN
  • ,WE HAVE CITY WATER & HAVE NOT HAD THIS PROBLEM WITH ANY OTHER ITEM. WE HAVE SCRUBBED,TRIED VINEGAR, RUST REMOVER, ALL SORTS OF CLEANERS WITH NO SUCCESS.
  • CAN WE GET A DIAGRAM ON HOW TO REMOVE THE COVER IN ORDER TO PRIME & PAINT THE DISPENSERS.
  • ANY HELP WOULD BE GREATLY APPRECIATED. OUR DEALER HAS AKNOWLEDGE THIS PROBLEM BUT HAS NO SOLUTIONS
tgmulc@bellsouth.net
  • glenn Sep 05, 2008
    SOUNDS GREAT - PAY HIM
Please send $19.95 AND i WILL SEND YOU DETAILED INFORMATION ON A UNIQUE SOLUTION
Posted on Sep 05, 2008
Maytag icemaker drips dirty water onto existing ice ini tray.
please check or install screen filter in the water valve at the back beside compressor
Jan 15, 2014 | Maytag AFD2535
Do you need to put a cleaning agent on a fabric lounge before using the steam fo the Steam Matey
I would say no, if you have a specialised stain clean that area first. Start with warm soapy water and if that doesn't work use zippo lighter fluid on the stained a area to remove the stain. Zippo lighter fluid is great for removing stains as it is our alcohol. Always try any cleaning agent on an area of the lounge that if it makes the stain worse it won't ruin the lounge I.e under a cushion. When steam cleaning any fabric you should check the fabric specifications to see if its suitable for steam cleaning. Some fabrics like macrosuedes that have a backing on the fabric will delaminate when wet and ruin the fabric.
Aug 30, 2013 | Kitchen Appliances - Others
My hp laptop stain problem, how to solved this problem please help me ?
Stain problem? I'm assuming you mean to say that you have a stain on the laptop somewhere? depending on where the stain is and what materials your computer is made of, the cleaning process can be dramatically different.
No one accurately tell you how to clean a stain without knowing what materials you have stained and with what substance you've stained them with.
Aug 04, 2013 | Computers & Internet
How can I remove coffee stains from a shirt?
To ensure the best results, you should treat the stain immediately. Begin by rinsing the stained area under cold water. If the stain is still there, try rubbing a mixture of liquid laundry detergent and water into the stain. Allow this to sit for about 5 minutes before washing.
Feb 07, 2013 | Wine & Spirits
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
My Whirlpool duet sport machine occasionally has "stained" laundry. I can't figure out what causes it since I don't wash colors and whites together. The stains appear to be blue. Could this be a fabric...
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
Sep 16, 2010 | Washing Machines
Glass and cups coming out with a milky stain on them, no shine at all.
Rub a little vinegar on the surface of an affected item. Does the stain vanish? If so then you have limescale deposits caused by no salt in the machine.
No salt can be an empty dispenser, a faulty dispenser, or using dishwasher tablets/powder without additional supplementary salt in a hard water area. it can also be caused by having the salt dispensing control set too low (on many models it's a lever located adjacent to the dispenser lid).
Mar 15, 2010 | Servis 23 in. M4306 Free-standing...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
81 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
