Question about Toshiba 50HP66 50 in. Plasma Television
Our display board was replaced now the y sustainer board needs replaced
Do you know where to buy board-The tv repair person wants $600 and I called the manufacturer given to me by Toshiba and they want 150 but will not sell to anyone except tv repair persons. I paid $2200 for the tv and it broke after 1 year.2 weeks.
Toshiba pd 4 ptthe first repair but would not pay for the second. TV is sitting in the room not working.
  • shady side Aug 13, 2009
    We just found out that Toshiba has replaced 2 boards and made them into one to fix the problems of their plasma tvs. We are awaiting an answer to see if they will pay for it also since we tried unsuccessfully to fix the problem at a cost to us which never fixed the problem and we finally just put the tv into a room and could not use it at all for a year.
    Problem Solver:
  • 5 Answers
Three suggestions:
Contact http://www.ptscorp.com/television.html. They have a selection of replacement boards or will repair it Fees are usually $50 to $125 and I have had great success with them.
Another would be to try www.shopjimmy.com and lastly do a Google search, if you know the exact part number, to find other sources for the board.
Posted on Dec 30, 2008
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
Nov 28, 2015 | Hitachi P50H401 50 in. Plasma HDTV
42" Plasma, no picture, sound
Hi:
The best possible solution to your problem is to replace both sustain boards at the same time, The X and Y sustain boards. LG tech support recommends replacing the digital board as well when replacing their boards, even during LG's tech training seminars they suggest you replace all major boards for continued viewing enjoyment. But in my experience you should replace the X systain also, but make sure the Y you replaced is still good.
Sep 08, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have no picture.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem.....
Jun 10, 2011 | Akai PDP4225M 42 in. Plasma Television
My tv will turn on but no picture of sound will show. The screen is completely black. When I press the power button on the remote the standby light on the tv blinks red twice then a smaller than usual...
I hope this will help in solving the problem....
Jun 09, 2011 | LG 42LG30 42 in. LCD HDTV
50 in taschba projection tv about 12 yrs old power light on but no pictyre thanks
If they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.if otherwise,
The TV have a 1 or 2 long board that is called the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards only job are to help to the CCFL LCD screen tubes to provided a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 refurbishes LCD inverter boards for the replacement.
I hope this will help in solving the problem.....
May 12, 2011 | Televison & Video
TV have sound but on picture, screen is black, can change channels, TV works like radio
You can solve this type of problem by opening the television, but caution must be taking to ensure proper troubleshooting, because the panel contains high voltages.
often that needs to be done in a service center as there are some adjustments to be made after replacement.
May 09, 2011 | Samsung LN-T1953H 19 in. LCD HDTV
Audio on blank screen !!!! wat to do !!! vistron tv
IF the backlights are on but you just get dim glowing on the screen when look at the screen in darkened room then the T-CON board is bad or it is not getting the 12vdc from the main logic board. Need to use logical troubleshooting before buying the wrong parts, but if otherwise then,
often that *needs* to be done in a service center as there are some adjustments to be made after replacement; don't know about this particular TV model,
Aug 03, 2010 | Televison & Video
Zenith 50pc3db troubleshoot green blinking power light no picture
That flashing light is either a failure of the power supply and or one of the drive boards (Y-Sustain, Y-Drives, Z-Sustain) to display the image.
The main board is seeing a problem and that is why the green light is flashing. You may have heard of "POP" sound before your TV started this issue.
Looking through the back cover of your TV and seeing the power supply, if the large capacitors’ tops are swollen or split, then you will know that is a source of your problem(s).
Beyond just looking at the power supply, to correctly trouble shoot your issue would require some TV repair tools and a little knowledge of electronics.
Your Zenith/LG TV was made around 2007.
Let me know if I can help you out any more.
Good Luck.
May 23, 2010 | Televison & Video
I have a 42" lg plamsa tv the screen went black and still had sound.. found a blown fuse on the board to the right of the power board, when i replaced the fuse,it will power up and then 5 seconds later i...
The fuse you have replaced would have been on the sustain board, now that it clicks indicates a problem either with the control board or the sustain board. You would need to disconnect the connector from the power board to the Y-sustain board (left of power board) to check if the Vs & Va voltages are present, if so then the power supply will be working ok & the problem will be with the previously mention boards. There is the possibility that the plasma display screen could also be faulty.
Nov 06, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
We were watching tv and all of a sudden we heard a
I had the same problem. We replaced the Y Sustain board. It was under $200 and not at all hard to do yourself. Remove the back of the tv. Make sure you watch what screw goes where. You will see the board on the left side. The number should be on the bottom right corner of the board. Just watch how you removed the board making small notes as to what goes where. Its really not that hard and you can save 600$ or more
Jun 06, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Toshiba 50HP66 50 in. Plasma Television Logo
348 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
