Question about Toshiba 2060 Copier
Copies have gray background.
The copies on my toshiba 2060 have a gray background. Is there any adjustment that I can make to make the background white like my original? I already have the dark/light setting set to the lightest.
  • Toshiba Expert
  • 1,326 Answers
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Posted on Sep 10, 2008
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Have toshiba 2060 copies are coming out with gray and blk stripe
Hello sir; Everything you can clean but drum, that's most sensity part, UNTOUCHABLE , I believed you damaged the drum already, go change one meanwhile change cleaning blade too.
Mar 09, 2009 | Toshiba 2060 Copier
Copies too dark
1-drum needs changing
2-wires needs changing (the cleaning doesn't do anything for it)
3-developper needs changing.
Sep 23, 2008 | Toshiba 2060 Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
Black line at top of copies
You could have a scratch on your drum. If you take a look at it inside the machine, see if it appears on the drum.
Jul 31, 2008 | Toshiba 2060 Copier
Toshiba 2060 Edges of copies cut off
One the cassette drawer, there is a key that indicates the paper size. It is notched in a way to tell the machine what you have loaded. These notches engage a set of switches in the front of the machine, visible when the drawer is pulled out. What happens, is the friont of the drawer moves. It is screwed down in two places I think. Loosen the screws, and align it properly. It should be obvious, because you need to align it with the largest line in the index set. The front drawer plate is adjustable is what I am trying to say. The switches will engage properly, and all should be well!
May 17, 2008 | Toshiba 2060 Copier
317 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
pkwc
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
