Question about HP Computers & Internet
Battery what's the best way to maintain baterry life (as far as charging, uncharging, use of dc etc.? thanks
    Genius:
  • 2,028 Answers
I commonly use the analogy, laptop batteries are like flash light batteries, the more you use them the quicker they wear out. This is true, with the exception of that laptop batteries are considerably more complex, and have built in regulators and fail safes. What you have to keep in mind is that it is still a battery and they eventually wear out, so, when ever possible keep it plugged in, and you will get the most from your battery.
Posted on Sep 04, 2008
Good question, im lookin forward to the anwser because i found that my laptop use to have 3 or 4 hours of batter, not it only has 1 hour and 40 minutes if im lucky :S.... why does this happen :S.....
Good morning! I have a question about the BlackWeb portable battery 9000 mAh. It does not seem to be taking a charge.
Batteries do wear out and can die. Their longevity can be increased with proper care and charge/discharge cycles but no matter what, the chemicals will erode rendering the battery fubar. Needs replacement. After replacement I would read up on the characteristics of the specific type of battery (ni cad, nimh, lithium, lead acid, etc) and use the procedures best suited for max life for the battery. Example - ni cads like to be fully discharged for best charging, etc.
Sep 23, 2017 | Televison & Video
What to do if my phone stopped charging
1. try to see if your battery contacts are clean. remove the battery and rub the contacts with an abrasive cloth or metal nail file. then try it to see if it makes contact and will charge.
2. some times, even a fairly new battery will lose continuity inside. To see if this is the problem you need and inexpensive circuit tester set on continiuity check. If you check from one post to the other you should get continuity, even if the battery is uncharged. Also during this process, you can also set your testor to dc mvoltage and see if you can get a reading. If you get a reading, then your bATTERY IS OK and the contacts are dirty. The battery has been charging, your phone just was telling you it was not charging. If that doesn't work, you teckkie people might go a little further, as described later. This mnext step is not recommended unless you have already had your children, and lived a great life so far. (to be continued)
Jul 10, 2014 | Alcatel Cell Phones
The Battery does not seem to charge so I want to remove it and see if it will charge if connected to an external charger. How do I remove the said batteries?
Remove the batteries .. Every Chair is different .. but if the batteries aren't charging it's probably that they were left uncharged for a time and they dropped down enough that the charger dosn't recognize them .. If they drop down below around 6 volts the charger won't charge them ... I have taken batteries out and charged them individualy with a car charger .. but they never come back .. at best half life.
Aug 31, 2011 | Pride Mobility Products New Pride Mobility...
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
My battery dies very quickly
If your notebook unexpectedly goes into Sleep mode while you are using it but the battery charge is not low, you may need to recalibrate your battery. You should also recalibrate the battery periodically to maintain the accuracy of the battery gauge. Follow these steps to recalibrate the battery.
  1. Connect your notebook to AC power and let the battery charge completely.
  2. Disconnect the AC power and restart your notebook.
  3. Completely discharge the battery.
  4. After the battery is completely drained, reconnect your notebook to AC power.
  5. Charge the battery completely until the battery status indicator turns blue.
Oct 28, 2010 | Gateway T-1625 Notebook
Laptop is not getting charged once it is switched on. where as when the laptop is off it is getting charged. Very much reduced baterry life.
I would start off by looking at the output voltage of the charger then pull out a volt/ohm meter and see if its actually putting out the correct voltage. If it is then u have a bad battery or DC jack in the laptop.
Aug 13, 2010 | Toshiba Satellite A135-S4527 Notebook
The baterry dies in 10 minutes.the motorcycle has only 6700km.should i change baterry?so soon?
Yes the battery can die in as little as 12 months if it is not used often, vibration and rough roads can also shorten battery life.
Check it has water in it up to the lines.
Put a multimeter across the battery should be just over 12v with engine stopped, rise to 13-14v with engine running to check charging circuit. Riding when the battery completely dies can overload the charging circuit.
May 14, 2010 | 2008 Yamaha XT 660 Z Tenere
My battery on my compaq cq50 140 us wont cut on
sir/mam you`re battery pack is need to re-pack or change the Battery pack.if you want to safe and long life Battery Pack if you use the unit inside youre house use only a charger then remove the battery pack from unit do not use both supply,like a battery with charger.if baterry full only battery,if you charge the battery charge only..
This is a only a tips For Long Life Battery Pack and Unit..Thanks
Apr 29, 2009 | Compaq Presario Notebook
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
