Question about Kitchen Ranges
I have a hotpoint gas range with electronic controls. When i put the oven on preheat the igniter glows but the gas does not come on. this problem happens 50% of time.
  • 1,543 Answers
You may have a low voltage problem, especially if it occurs at about the same time every day, but more likely you will need to replace the igniter. Even though you see it glowing, often times as they age they start to draw fewer amps, resulting in your exact symptoms.
Posted on Sep 05, 2008
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
My hotpoint. Has burner activity. The electronic oven will not light, makes no sound when the temp knob is depressed, nor with a match under the burner will it light. Makes no sound through trying each...
Ok
Is your igniter glowing when oven turned on.Look for bright orange glow near burner.If yes ,and no ignition,then igniter is weak and needs replacing.No glow at all,then a voltage test at the igniter needs to be done to see if it might be thermostat problem. Very common for igniters to go.Most likely cause.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven will sometimes preheat to temp, sometimes not, when it does it will not stay hot enoughto cook the food...replaced control board...still dont work..checked thermostat, works fine. glo plug...
if it's glowing but not igniting the flame in less than 40 seconds you have a lazy ignitor,change it out.open the draw unser the oven door and on the left or right side of frame not the door you'll see a tag with the model and serial number,give your parts store the model number and they'll give you the correct ignitor
Sep 22, 2010 | Hotpoint RGB745 Gas Kitchen Range
Maytag Prec touch 750 lower oven takes too long to preheat
This is a common problem that happens when the oven gas control valve is sticking. This can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 23, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Oven igniter glows red, but no gas fire.
The oven igniter is glowing so that tells me the circuit is sound, the oven control is working, and the oven safety valve is ok. That means only one thing. Weak igniter. The igniter must draw 3.2 amps in order to open the safety bi-metal inside the valve. Bumping or tapping on the stove will make the oven light off. Solution replace the igniter. I have repair photos HERE
Feb 03, 2010 | Hotpoint RGB535 Gas Kitchen Range
Burners work,Broiler works but oven does not preheat
If everything works on your range, but the oven, the most likely culprit is the igniter for the BAKE manifold. What is confusing me, though is the statement in your question where you say the "oven will light up, but never get hot". Yet, you say the oven does not ignite. Can you clarify this? In some ovens the BAKE and BROIL manifolds BOTH light when preheating, to reduce the warm up time. Once the desired temperature is reached the manifold not in use, will shut off.
In any case, on a gas range, the burners for the BAKE and BROIL manifolds use an electric glow bar type igniter. There's a separate igniter for EACH burner. When you make a bake or broil selection on your oven control, the respective igniter begins to glow. After the igniter reaches a certain current potential, the gas safety valve is opened, gas flows to the manifold, and voila! You have ignition. It can take as long as 90 seconds for the burner to ignite. What can happen over time, is the igniter becomes weak or fails. If the igniter becomes weak, it will still glow, but it never reaches the desired current potential to open the gas safety valve. The result: you end up with an igniter glowing with no ignition. And, if you're like me, you're left scratching your head wondering why the thing isn't working when it "looks" like it is. You can easily tell if the igniter is working by opening your oven door and selecting bake. Watch the oven pan in the bottom of the oven. You should see an orange glow coming from under it. It here's no glow at all, the igniter has probably failed. If there IS a glow, a current reading will tell if it's within tolerance. The following link explains more on these igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter is a common fail item as it gets used more frequently than the broil function. On your range both igniters are interchangeable. You can purchase replacements on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. The part number is WB2X9154. Shop all three sites for the best price.
I hope this helps you. If my assessment of your symptoms is wrong, or if you need further assistance, please let me know.
Jan 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven not heating(magic chef
Sure. If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often.
Aug 25, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven
From MNTECH, "If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often."
I live in Japan. I got a brand new range in june and it has had this problem for four month. The igniter glows but the gas never (or rarely) releases. Often it would preheat but not maintain the temp while baking. **augh** After reading MNTECH's solution I got a transformer and plugged my range into it to change the voltage (100 to 110) and I haven't had a problem since. THANK YOU MNTECH FOR POSTING THIS SOLUTION
Aug 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
