Question about Canon EOS 400D / Rebel XTi Digital Camera
Changing the resolution on my camera before i go to photoshop
I understand  that when i go into photoshop it says 72 resolution and i change it to 300 so i can get a perfect 11x7 picture or what not. . . I dont know how to change it on my camera to a higher resolution so I can make HUGE PRINTS!  I have a canon rebel xt  and i am hoping to make picture 20x20 (maybe even higher if it lets me) with still a good resolution
  • campis1 Sep 09, 2008
    I have the same problem, I don't know how to change my camera settings so my photos will be at 72dpi when I open them in PhotoShop.
  • Anonymous Oct 25, 2008
    I have the same problem on my canon eos 1000d. i can not change the resolution up to 300 on my camera.
  • 3 Answers
Using the RAW setting will give a higher quality photo, the other formats compress to jpeg causing you to loose some of the original photo information. the ZoomBrowser EX program allows you to edit the RAW image, I recommend getting the large prints done at Kinkos or some place like that. I've gotten poster size prints done that look very clear. Use a tripod to combat camera shake, it is very apperent at that size of print. Also a low ISO to help reduce noise.
Posted on Sep 11, 2008
  • 23 Answers
You can't adjust DPI on a camera. You can adjust pixel count. In your manual on page 60 it tells you how to set image quality. Looks like the "L" setting will produce somewhere in the 16.5x11.7in paper size. To change DPI that is done in your editing software on your computer such as Photoshop. If you use photoshop, find your manual and read it. If you take it somewhere to be printed tell them what you want and they should know what they are doing.
Posted on Dec 04, 2008
  • 56 Answers
As far as I know it is not possible to change the actual dpi on the camera, make sure that the megapixle count is set as high as you can on the camera.
You should be able to enlarge the photo on the computer at 300dpi, up to about 400% (using bicubic resize).
Posted on Sep 10, 2008
72 dpi instead of 300dpi
You do this in your editor. In photoshop you go Image -> Image Size and you'll see resolution set at 300 as default just change the 300 to 72.
Apr 25, 2016 | Canon EOS 60D Digital Camera
Can I change 70 dpi to 300 dpi in my canon 60d camera?
Apr 25, 2016 | Canon Cameras
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
Why does the FinePix E510 pictures download from the camera at 72 dpi when the camera was set to take 500 megapixel photos? I cannot find any way to adjust this in the finepix manual or in online help. I...
A couple of things - I don't think you mean 500 megapixels (that is a lot!) but I assume you mean you expected a high resolution image. You may have it! The dpi setting is largely irrelevant (for photographers) as it simply relates number of pixels to a (notional) print size. Thus an image that is 3000 pixels wide (say) would print out to 10 inches at 300 dpi (3000/300) or 40 inches (approx) at 72 dpi (3000/72). the image has the same information /resolution - it's just "spread" further on the larger print. You can easily change the nominal dpi in e.g. Photshop Elements but it won't affect your image quality.
If however you are getting low resolution images when setting the camera differently that's something different. I would need extra info to help there but pssibly check if the camera was set to RAW and maybe you were looking at the (small) JPEG usually saved with it?
Jun 27, 2009 | Fuji Finepix S5800 Digital Camera
Photo resolution
Sony H1 takes photos at 72 dpi by default. But the picture quality will be good. if you want to convert it to 300dpi open the picture in adobe Photoshop and select image size and change resolution to 300 dpi. but the file size will be very high to up load. if you want to reduce the file size select the image size in adobe photoshop and reduce it according to your requirement. if my solution proves good please rate it. Regards.
Feb 04, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
In elements 6 go > Image > Resize > Image size > Resolution change to 300
May 07, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Resolution
Many cameras will take pictures at only 72 dpi. Changing the resolution causes the camera to change the size of the picture in terms of pixel dimension (ie 800x600 vs 640x480) but always at 72 dots per inch. A photo editing program like Photoshop can change the resolution to whatever you need.
Dec 13, 2007 | Samsung Digimax 4010 Digital Camera
Canon Rebel xti vs Photoshop!
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Minolta Dimage S414 Problem with resulution
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
264 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
